Old 05-30-2007, 08:49 PM   #1
Birdman12
Birdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really nice
stripped block..help!
so after putting in the T28 which is NOT i repeat NOT a direct fit from the T25, with everything back in after the first start up it starts squirting out oil. so i check and its leaking between the block and oil line fitting from the turbo... turns out the threads in the block are stripped! im very frustrated right now, ive tried using some teflon tape to seal it up, i tried more washers, still nothing.
can someone help me please, some suggestions on what to do and if anyone else has had this problem let me know what you did to fix it. and yes i know most people will just say re tapp it, so thanks but that will be my last resort. please help.
Birdman12 is offline   Reply With Quote
Old 05-30-2007, 09:13 PM   #2
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
This just happened to a buddy of mine. He ultimately had to put a helicoil in the block..and all is well.
here are 2 other threads of people with the same problems, i am sure there are others that can be found..
http://www.zilvia.net/f/showthread.p...stripped+block
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 05-31-2007, 05:13 AM   #3
nassin31spr
nassin31spr's Avatar
nassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to behold
The size is M12x1.25. Drill bit size is 31/64. Just drill, tap, put in the coil and your back to new. But practice makes perfect so at least try it a couple of times on something else first. You can buy a helicoil kit from your local hardware store, auto store or even eBay. If you need any help along the way just post up your questions and someone will speak up. Good luck.
"Home is where the armor is"
nassin31spr is offline   Reply With Quote
Old 05-31-2007, 05:26 AM   #4
Rockogtr
Rockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the rough
Send a message via AIM to Rockogtr
i did the same thing but with the coolant port...sucked but i tapped it and no more leak ...what are you using for a turbo??? i did the 2871r w/ the .86 a/r and like you said bull shit thats a direct replacement
Rockogtr is offline   Reply With Quote
Old 05-31-2007, 08:56 AM   #5
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
i did the same thing with the coolant hard line...i just put RTV/threadlocker on it though...
benefitx is offline   Reply With Quote
