Old 05-31-2007, 12:08 PM   #1
cutter
cutter is on the path to ruincutter is on the path to ruin
Send a message via AIM to cutter
car running rich at idle with power fc d jetro
well i put my fully built motor in, and hooked up the wide band, and hooked up the power fc. the cams i have are very lopey, but i can hear a slight misfire at idle and when i rev it. but the wide band read that i was running between 10.5 and 11.5 afr at idle.
fuel pressure is at 44 psi, and injectors are pulsing. i can hear them pulsing and i the idle gets worse if i dissconnect each plug one at a time
does it matter if the coolant hoses on the aac valve are switched?
is there a was to see the percentage of output from the aac valve on the commander?
what about tps voltage on commander?
i just cant figure out why it is running so rich. if any one can give , me any leads i would greatly appresciate it.
cutter is offline   Reply With Quote
