Old 08-16-2002, 10:04 PM   #1
jarnld
jarnld is an unknown quantity at this point
what things would you guys suggest buying nd in what order before turboing a 95 KA? (clutch, fuel, fuel rail, injectors, fuel management etc.....)
If you could provide a manufacturer along with the product that would be great.  Ive already considered magnacor wires and ngk plugs, unorthodox racing pulleys, clutchmasters stage 4.  Im really concerned about fuel management more than anything else.  Thanks guys.
there is a barber in town that shaves only people who do not shave themselves.  Does he shave himself?   think about it...
jarnld is offline   Reply With Quote
Old 08-17-2002, 12:43 AM   #2
/etc/shadow
/etc/shadow is an unknown quantity at this point
Haltech E6K?
Seriously, the opinions I've heard on why a lot of KA24DE+T's blow up is because of improper fuel management. The E6k will help you with that, and more.
/etc/shadow is offline   Reply With Quote
Old 08-17-2002, 02:09 PM   #3
speedemon
speedemon is an unknown quantity at this point
i am also planning to turbo my ka. it would also help me to know what to do before turboing the ka..
speedemon is offline   Reply With Quote
Old 08-17-2002, 06:15 PM   #4
phatsx
phatsx's Avatar
phatsx is an unknown quantity at this point
I have a internally stock turboed ka24. I have a cartech rising fuel pressure regulator and a walbro in tank 255lph high pressure pump. I am running 7psi on stock fuel system other than what I just mentioned. You definately need the clutch and good wide tires at least a 245. You however do not need the haltech e6k. I would also get a larger exhaust 3" or more for the best power gains. I would also run iridium plugs I've tried many and they work the best by far. I use denso's but ngk's also work well. If you want run more than the 7psi that I run I would definately get injectors and a jwt ecu,maf, and fuel rail, and larger injectors any more than 10psi requires internals. As far as wires I prefer taylor they fit well work well and have a good warranty. The magnecores are good wires but if you have any trouble with them your on your own they won't warranty them. I would also run mobil 1 oil.  Before I put the kit on I ran mobil 1 and changed the the oil at 1000 mile intervals 3 times to make sure the turbo would get fresh clean oil. When you do the clutch make sure to resurface the flywheel I tell this to everyone because this is very very important. While your under there you might as well change the tranny fluid to redline and add some lucas oil stabilizer to the fluid. I have a question for you are you planning on purchasing a kit or piecing it together. If your buying a kit I would recommend fmax or nsport. I personally have the nsport kit and praise there quality.
Nsport turbo kit, JWT ecu, JWT fuel rail, MSD 72lb injectors, Cobra MAF,SPEC clutch, KYB agx shocks, Eibach Pro springs,Apexi GT Spec exhaust, 18x8 Konig flight wheels, BFG KDW 265/35/18 (rear) Dunlop fm901 225/40/18 (front), indash tv and dvd player with ps2 and some more stuff that I probally can't remember
1/4 Mile:13.9 @ 105 / 7lbs of boost w/o JWT mods
http://www.eframes.com/default.asp?g...bum=38203.2910
phatsx is offline   Reply With Quote
Old 08-18-2002, 03:27 PM   #5
MyFirst240SX
MyFirst240SX is an unknown quantity at this point
what kinda boost controller, turbo timer, and BOV are you using? also what size turbo?
thanks
It is better to drive a Slow car fast than to drive a fast Car slow!
'89 FastBack 5spd: Intake/Exhaust,Strut Bars and JL15.
'90 Parts car/Some day drag car.
MyFirst240SX is offline   Reply With Quote
