Old 06-05-2007, 05:09 AM   #1
D1champ
D1champ's Avatar
D1champ is on the path to ruinD1champ is on the path to ruin
Question w/ illustration
Hey guys, want to run a catch can but I have 2 questions I haven't found the answer to by searching so here goes:
D1champ is offline   Reply With Quote
Old 06-05-2007, 06:04 AM   #2
g6civcx
g6civcx's Avatar
You need to search more. That piece is the air-oil separator. It does what the name implies.
You can run a hose from here to there, but expect blowby.
You need to rethink how you're going to route the catch can. There are many writeups and many options to choose.
Old 06-05-2007, 06:33 AM   #3
D1champ
D1champ's Avatar
Problem is the new SS manifold interferes with the mounting points of the air/oil seperator...any suggestions?
Old 06-05-2007, 06:58 AM   #4
G-spec
G-spec's Avatar
G-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of light
since your running a oil catch can, there shouldn't be any blow-by issue from routing the back hose as you have drawn it. Alot of aftermarket manifolds come with a hose to replace the seperator upon installation. I've been running mine like that for 2 years now with no signs of blow-by, and thats without a catch tank also...just a breather filter n the front side of the "t"
GT3076r-boosted blacktop sr20det, s13 coupe
Function over Form...
G-spec is offline   Reply With Quote
Old 06-05-2007, 07:27 AM   #5
grnappletree14
grnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfection
yea my manifold interfeers with the sr head where u mount the screw into for the oil cat can. does any1 know what to do. im confuesed to
grnappletree14 is offline   Reply With Quote
