6k budget SR20 swap need input
Ok so heres my situation this past friday my car over-heated (DOHC KA) due to my radiator cracking and the motor sounds like it has no compresion at all. I am trying to put together a parts list that is within my 6k budget. The motor is an S13 Blacktop @ 2700$ with everything included except the following: Exhaust, Downpipe, BOV, Intercooler, Clutch, Injectors, Radiator, and Fuel Pump. I would also like to throw in a boost controller, most likely MBC because they're cheap or a 2-in-1 gauge/controller setup. The motor will be going into an S13 coupe. My question is what parts do you guys recommend to fill the above mentioned spots. I really would rather avoid buying Megan everything to make budget, if you think I would have to do that to make my 6k cut-off then say it. Vendors feel free to chime in with some deals you have going on right now that may help me out. Any and all intelligent/serious responses are greatly apreciated, thanks in advance.
In the market for a Clean Coupe
