![]() I search SAFC w/ Z32 and found what I needed just really wasn't all to clear. I have a s13 redtop w/ a Z32 MAF what does the in and out need to be. I read 2 and 6 or 2 and 5. also heard2 and 2 from ethaphy. Also after you put that in it goes to a calc screen in 2 and then Add. whats that mean. And are the settings the same for a Q45 MAF if the z32 one doesn't work I m going to install that. If you guys can help me w/ the right adjustment that would be great. Thanks
#5 |
![]() Join Date: Jun 2004
2 in 6 out.
In represents the AFM you have chosen, Z32 which is represented as 2 Out represents the AFM the Ecu is anticipating, which if it is a stock ecu for an s13 redtop would be 6. You probably read enthalpy telling someone to use 2 in, 2 out for one of his tuned ecu's anticipating a Z32 AFM. 2 in 6 out is what you need, if it does not, something is wrong with your setup.
[email protected] |
#8 |
Q45 is different, DL the pdf for the SafcII and look at the hotwire number next to the corresponding model year of q45 maf you have, that will tell you what value to enter for said AFM.
[email protected] |
