Old 06-25-2007, 03:20 PM   #1
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
hicas power steering pump
hey everybody...i have a question, i have a hicas pump that came with my sr20
but i dont have hicas...can i still use it or can swap my ka24de pump instead?
ecuastyle84 is offline   Reply With Quote
Old 06-25-2007, 05:14 PM   #2
Enjin
Enjin's Avatar
Enjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enough
Send a message via AIM to Enjin Send a message via Yahoo to Enjin
short answer: yes you can still use it. search on how to use a hicas sr20 pump on a non hicas car. it involves removing that big bolt on there. I would type it up, but Im sure there is a thread that you can search for which gives you much more detail
1991 Nissan 240sx
www.tractionoptional.com
Enjin is offline   Reply With Quote
Old 06-25-2007, 05:16 PM   #3
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Not sure about the SR Hicas pump but if it's the same as the RB hicas pump... You take the ass end off the pump (4 10mm bolts iirc) and remove the little vanes from the rear (hicas) portion of the pump. Then you reassemble everything and block off the 2nd output. This disables the hicas section of the pump so it doesn't generate pressure, and of course the plug stops it from leaking ps fluid everywhere.
MELLO*SOS is offline   Reply With Quote
Old 06-25-2007, 05:25 PM   #4
ecuastyle84
ive heard of that on the sr hicas pump by removing the ass end off...i cant just plug up the hole with the same size bolt or it will generate pressure right?....ive heard the dohc ps pump works with the dohc bracket off my ka24de...the only thing is one bolt wont fit
Old 06-25-2007, 05:32 PM   #5
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Yes. That's why you take off the ass end and remove the impeller blades so it can't generate pressure on the hicas port. Then you just need to find a way to seal it off; I had mine welded by the alt/rack/pump rebuild shop.
Old 06-25-2007, 05:41 PM   #6
zackt69
zackt69 is making a name for him/her selfzackt69 is making a name for him/her selfzackt69 is making a name for him/her self
I'm in the middle of doing this right now. I already took the rear off the pump and removed the little square blades, plugged up the 2nd hole, then I tried to connect everything. Turns out one of the larger rubber hoses off the hicas pump is huge compared to the hose on the non hicas reservior. I think unless you use a hicas pump and hicas reservoir you'll find the same problem. I had to go out and find a reducer from one hose size to the other... just something else to look out for.
zackt69 is offline   Reply With Quote
Old 06-25-2007, 07:34 PM   #7
ecuastyle84
does it have to be welded?...cant i just remove the blades and put it together and plug up the second hole?
Old 06-25-2007, 11:10 PM   #8
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Yes. Doesn't have to be welded. Just make sure you seal the hole or it will leak. Also as someone mentioned above, you will have to find a hose that is large and then get reduced. I had that problem. Just took a heat dryer gun and then took some hose and use a needle nose the widen it. After a bit of doing so the end will remained widened. I been using my setup like this for about 7 months no problems, thats also with about 12psi of boost.
Luvs2slide is offline   Reply With Quote
Old 06-26-2007, 06:45 AM   #9
Rayne
Rayne's Avatar
Rayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfection
If you care to have a HICAS reservoir I may still be able to get one.
Rayne is offline   Reply With Quote
Old 08-27-2007, 10:23 PM   #10
MelloS13
MelloS13's Avatar
MelloS13 will become famous soon enoughMelloS13 will become famous soon enoughMelloS13 will become famous soon enoughMelloS13 will become famous soon enough
I have a KA24de with HICAS and would like to disable it I’m very interested in this method. could someone show pics of the process of plugging the lines. I’m going to use SPL eliminator kit to remove the rear rack. but need help with pump issues
MelloS13 is offline   Reply With Quote
Old 08-27-2007, 10:53 PM   #11
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
http://www.240sxforums.com/forums/sh...ght=hicas+pump
Jtuned_andy is offline   Reply With Quote
Old 08-28-2007, 10:11 AM   #12
Sileighty_85
Sileighty_85's Avatar
You can use the KA Non HICAS P/S Pump I did it to mine Just "Notch" the back aluminum section (grind it away until it fits) I've had no problems with mine
(I couldnt see the link cuz of these PC's.)
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
