Old 06-30-2007, 12:55 AM   #1
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
Write-Up RPS13 Harness Relocation Under Fender
Why do this Mod? As you lower your car, and most importantly if you slide you car you will find yourself rubbing the fenderliner, a piece of metal, and eventually the motors harness. There are many ways to accomplish the task of removing this risk. I debated on buying ready made parts, buying sheet metal to put over it, pulling it through the engine bay, and then decided I would recloate it the way I saw in a few threads while researching last night. This is pretty damn easy, I added some extra stuff while I was in there. One key thing to mention is if you take the sides skirts and the front bumper off, you will save at least 30 minutes in the long run. I left them on and it became a PITA to maneuver when taking off and reinstalling the fender.
Tools Needed
Jack and Stands
10mm Wrench, shallow and Deep Sockets with extensions
12mm Wrench, shallow and Deep Sockets with extensions
Phillips Screw Driver
Channel Locks (I used a vice grip, I will now buy channel locks)
Drill with Bits
Sandpaper
Paint
Zip Ties
BFH (Big Fuckin Hammer)
1. First thing you wanna do is jack the car up and remove the front wheel(s). Once you get the wheels off, you can remove all the bolts that hold the Fender in from the top. They are the (3) you see in this Pic, and then there is another one at the very top not seen in this picture.
2. Then move down to the rear side of the fender as seen in PIC 1 below. Here you have the screws that are holding on your side skirt to take off, (REMOVE THE WHOLE SKIRT, IT WILL BE EASIER IN THE LONG RUN). Then looking at the bottom of the skirt in this picture on the right side there are (2) more bolts that hold the fender to the chassis, mine were rusted to shit, spray them down with WD and wait a few minutes, also use a 6 point socket not a box end wrench. The last bolt for the rear of the fender is on the back left side of the fender. Then stay low and move to the other side and undo the screws or zipties that are holding your front aero on. There is one bolt here as well for the fender on the lower side(TAKE OFF THE AERO, THIS LAST SCREW IS A BITCH WITH THE AERO ON). Then the last bolt for the Fender is in PIC 2 below. Once all of these are out, you can first pull out the fender liner smoothly and then with someone helping you, each grab one side of the fender and pull it out:
3. Now that the fender is out you can see what has been or can really fuck up your car and tires. 1st is the Harness sitting there, and then you see that piece of metal. I have nice slits in my neovas from that metal piece. The picture is not showing 3 dimensional but these are roughly sitting flush together. The metal part is recessed behind but sticks a bit lower. If you are still running a liner like I was, you can see a slit in your liner from the metal piece. This is the stock position for the Harness.
4. The way I chose to relocate the Harness is to pull it over the inner fender Lip rather than through the engine bay. I did this for cleanliness of the Bay and as well didnt wanna fuck with the wires. In this Pic you can see the ledge I am going to run it over. I will use Big Ass Zipties to hold the Harness in place. There are some holes already there for you. The one I am pointing at here is perfect for these big zip ties. All I had to do is drill a corresponding hole underneath to secure the ziptie and hold the harness in its new location above the lip. Just pull some slack on the harness. There is slack, but not tons. Pull from the front of the car, not through the firewall side as there is no slack there but a bit. As you pull it up and over, secure it with the first ziptie through the hole you just made, make sure you run the ziptie under the hoot latch and wiper washer tube so as not to bind them down.
5. Now for the second hole, this was convenient as well there was a top and bottom hole already there, if there isnt one, just drill one out. Again pull the harness up and over the Lip and then secure it with a Ziptie. Have someone hold it for you so you can get it really snug.
Once you get it secured, you are done with the relocation and it should look like the Pic below. See how it sits on the Lip? As you can see, I left the Loom on the harness, I should have taken it off as my fender was a bitch getting back into position with the big ass loom.
6. Now that you have the harness relocated, its time to take care of that nasty piece of metal that will shred your tires. What you want to do is get some channel locks and start bending the metal inward towards the vehicle. Start from the outsides and work your way in, you just wanna get it facing inward. You can see in the pics what I mean:
7. Once you get it bent in, take your BFH and pound the fuck out of it like a 20 Dollar Hooker on payday when your wife has been bitching at you until it's as flat as possible Like in this pic
8. Your newly flat piece of metal is gonna look a bit shitty, so get some 100 Grit sand paper and sand it down. After it is nice and smooth, hit it with some primer and then paint. It will look like this when it is done.
Now just have to reinstall the fender, your skirts and Aero. While reinstalling the fender, do not torque any of the bolts down all the way, just get them started. This will enable you to have some play as it will have altered a bit while off the car, it is some cheap ass sheet metal. Once all the holes have been hooked up, then torque them down one at a time working from left, then right, then towards the center.
Now you can move to the other side of the car and flatten out the metal piece on the passenger side.
Drop the car and go beat your car some more or Drink Heavily.
Late
Daryl
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline   Reply With Quote
