Well, at the dnyo day yesterday I ran once stock and then borrowed beissen's injen w/extension for my 2nd run. The air temp sensor connector from my car didn't fit his intake, so we just plugged it into the one on my stock air box and just laid it there. The dyno run went fine. then we put the stock intake back on, and when I started the car, all was well...but as i accelerated for the 1st time driving away from the shop, the engine light came on. Everything felt and sounded fine...still does, just the light is on. All the hoses and connectors are connected correctly, I even drove home with the light one...no problems.
I can't figure out how to get rid of the light. I cannot get the ecu to reset <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt='
Ironically enough, I'm using the FAQ that I posted (not wrote)
here on how to do this but I can't make it work.
I got the code (41-air temperature sensor circuit) but I already knew that's what caused the error. I don't know what I need to do to correct this "problem" or get the ecu to reset.
