Old 08-27-2002, 07:25 PM   #1
91blk240
91blk240 is an unknown quantity at this point
I am having a problem that seems to happen around half throttle.  It doesn't matter what the RPMS are at.  When i go to half throttle or higher the motor seems to cut in and out really bad, it seems like its missfiring.  If i rev the motor out of gear it oesn't appear to do it that bad.  I tried driving it at full throttle in 4th gear at a low speed and it cuts in and out even at really low RPMS.  It starts to happen really bad at around 2 psi.
I really don't know where to start so if anybody could help me out i woul appreciate it.  Its an S13 redtop in a 91 240
Thanks
RIP: 91 Black Coupe - Lost in Katrina
Current: 93 Black Coupe blown s13 blacktop
91blk240 is offline   Reply With Quote
Old 08-28-2002, 09:01 AM   #2
S14 Drift!
S14 Drift! is an unknown quantity at this point
What is your sparkplug gap set at?
It should be around 25 ~ 30 not more then that...otherwise you'll get misfire!
S14 Drift! is offline   Reply With Quote
Old 08-28-2002, 09:17 AM   #3
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
Might be the TPS. I had a bad TPS and my motor would backfire when I applied a lot of throttle.
Try adjusting it for sits and giggles. What rpm do you idle at?
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
