Old 08-02-2007, 12:37 PM   #1
Ninjabread
Ninjabread's Avatar
Tranny noise? Identify this sound!
Ok, well I've installed a Centerforce stage 2 for fun.It was fine for 2 days, but now something is making a noise towards the front of my tranny. It only does it on deceleration, and revving down.
At first, I though it was my exhaust hitting the chassis due to my new solid subframe bushings changing the location of the exhaust a bit, but upon further inspection, I realized that it's coming from the rear of the motor / tranny.
The best way I can describe the noise is kinda of like a rod knock. I can also feel the vibration through the clutch pedal when it's making the noise.
I'll have a video up in a few minutes, any help is greatly appreciated.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 08-02-2007, 12:52 PM   #2
Ninjabread
Ninjabread's Avatar
There we go.
613DriftWerks.ca
Old 08-02-2007, 02:48 PM   #3
Ninjabread
Ninjabread's Avatar
Someone said loose flywheel? I hope not.
I had to take it off to remove a snapped PP bolt, and when I put it on, I only torqued it by hand. fuck.
613DriftWerks.ca
Old 05-22-2008, 02:03 AM   #4
Sean14
Sean14's Avatar
Sean14 can only hope to improve
Could be loose flywheel bolts.
Sean14 is offline   Reply With Quote
Old 05-22-2008, 01:19 PM   #5
Tulok
Tulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really niceTulok is just really nice
throw out bearing?
just throwing something out there(no pun intended)
Even though it is hard work, you had better just take the tranny back off and make sure everything is ok. Unless of course you forgot to bolt the transmission mounts on tight.
Tulok is offline   Reply With Quote
Old 05-22-2008, 01:23 PM   #6
GSXRJJordan
GSXRJJordan's Avatar
Almost definitely a loose flywheel, sorry Matt.
Those flywheel bolts need 110ft-lbs. Get a special "flywheel bolt socket" basically a multi-star 14mm socket, and a 18" breaker bar, and do it right.
Old 05-22-2008, 03:11 PM   #7
Impact Black
Impact Black is an unknown quantity at this point
Whenever you do a clutch job, the reason for the tq specs is so that at the speed it rotates that nothing comes loose.
Its always good to check and double check the tq on the bolts.
Make sure that the pressure plate bolts are tqed down
the actual flywheel itself is tqed down, and heaven forbid you snap a flywheel bolt.
Impact Black is offline   Reply With Quote
Old 05-23-2008, 12:34 AM   #8
GSXRJJordan
In my experience, OEM flywheel bolts are a hard enough material that if they snap, they can be EZ-out'd. Only once did I have to weld a small nut on there to get one out (but that one just had a cracked head, didn't break below the head like most of them that snap half way down the shaft).
Let us know what you find when you crack that tranny open.
Old 05-23-2008, 10:20 AM   #9
Style
Style's Avatar
Style is on the path to ruinStyle is on the path to ruin
are you sure its not the tranny mount? or your driveshaft? ive never heard a throwout bearing or a clutch make that noise.
Style is offline   Reply With Quote
Old 05-23-2008, 11:06 AM   #10
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
something is loose.
I did not have a sounds like that, but I was on the highway. I had my flywheel bolts come loose on my car. Me and my dad were both 95% sure that my motor was toast.
I would start taking stuff apart if I was you.
KA-T_240 is offline   Reply With Quote
