help with gas gauge have standalone
just notcied that my gas gauge isnt working anymore, thanks to wonderful megasquirt. anyone know how to or have any ideas on how to wire it up on its own without the factory ecu. thanks
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Post what year you've got, and whether you have a HUD if it's an S13. I'll check the wiring diagrams. On most years, the stock ECU isn't connected to the fuel gauge at all. Do all your other gauges work?
Like Matt said, all the stuff on the cluster except Tach are seperate from the ECU. So megasquirt wasnt the cause it was either it failed or YOU.
It doesnt matter if its analog or HUD I've used both and they all worked fine. |
#5 |
matt. its a 97 .
other dudes, i didnt think ms broke my gauge ![]() my car had some weird electrical meltdown, thats when i decided to do ms.now i cant get the ms to communicate with the laptop. im using a usb cable to comm port.it just seems like its been one thing after another.getting a lil frustrated. |
#6 | |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
I never knew you could do that with an eggplant |
#8 |
On this model, the fuel gauge just wires straight to the sending unit. Check to see if you're getting a voltage at the sending unit from the gauge.
You won't get a spark until the Megasquirt gets an RPM signal. Does the Megasquirt work on a Stim? |
#10 |
It's an extra diagnostic board. Without it, the first thing to check is if it's getting a signal in at pin 24 that is going from 0 to 12 volts and back again as the distributor turns.
