Old 08-04-2007, 08:40 PM   #1
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
bolt on the front frame for bumper support broke, how to install a new one?
so i was in a small accident and the bolt that goes through the bumper support broke off. it goes through the frame. so all that's left is a broken bolt in there. i can't seem to get it off i've hammered at it, heated it up w/ blow tourch and try to hammer it, it just doesn't seem to budge. anyone have any idea?
240meowth is offline   Reply With Quote
Old 08-04-2007, 09:22 PM   #2
cotbu
cotbu's Avatar
that's because it's screwed in..... screw it out!
Old 08-04-2007, 09:31 PM   #3
Phlip
Yes, I look like that
Phlip's Avatar
Screw extractor, you can get one at Lowe's pretty cheap.
... get one big enough to not break when you go to use it.
http://homerepair.about.com/od/inter..._extractor.htm
Weirdo
And I write too!
Old 08-04-2007, 09:38 PM   #4
240meowth
it's a screw? the back end feels like a huge round thing, i think it's welded. here's some pictures just to confirm
this bolt
i cannot get this one out
Old 08-04-2007, 09:42 PM   #5
slamdbusa
slamdbusa's Avatar
slamdbusa is an unknown quantity at this point
It's a stud they aren't to be removed. In this case drill it out, and tap it and put in a bolt. That's how you fix this problem.
~Matt~
slamdbusa is offline   Reply With Quote
Old 08-04-2007, 10:02 PM   #6
bardabe
bardabe's Avatar
^^^^ yep what he said
Review Thread
bardabe is offline   Reply With Quote
Old 08-05-2007, 02:53 AM   #7
240meowth
sweet, thanks guys, i drilled the crap out of it and used a new bolt. now i can go drifting and turn up my electronic blow off valve! ha ha
