Old 08-20-2007, 09:41 PM   #1
dued
dued's Avatar
dued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymore
s14 Front End crash, now car shakes?
I had a front end collision about 6 months ago. The frame damage included a ripped out bumper support bolt and bent up radiator support.The damage was repaired by a body shop that bent the metal back into place (to save costs rather than having them weld in new support.) The car is currently repaired with all panels aligned properly, so I'm assuming that the frame is in proper alignment. Now that I drive the car up to 65, i get a noticeable steering wheel vibration, but past that it isn't so bad (80+). Is this frame still good? What could be causing this?
dued is offline   Reply With Quote
Old 08-20-2007, 09:46 PM   #2
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
did you check to see if any of the suspension components were damaged?
Old 08-20-2007, 09:47 PM   #3
JDMwannaBE
JDMwannaBE's Avatar
JDMwannaBE is on a distinguished road
my s14 was hit the same way on the passenger side but didnt touch the frame rails. you should be able to see them beside the engine on each side to check for damage. have you had the front end checked? get your allignment checked, along with your toe, and camber, and caster. go to a good shop though, alot of people dont know how to correct all that. a reputable shop would be able to provide you with a printout of what they corrected so request one if you can. it doesnt look bad from the pics though. good luck
JDMwannaBE is offline   Reply With Quote
Old 08-20-2007, 09:52 PM   #4
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
My car had similar damage, it didnt look too bad from the outside, but the VERY front of the rail was kinked.
Nothing enough to affect alignment issues nor body panel alignment issues either.
Alignment.. like others said, just take it to a quality shop and they should be able to figure it out.
Plus, check your bushings/linkage and most importantly your lugnuts..
lol, I've seen people complain of juddering/shaking and it was the lug nuts.
Get the wheel completely flush on the hub/rotor while the wheels are completely off the ground.
then drop it and torque it down.
babowc is offline   Reply With Quote
Old 08-20-2007, 09:52 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Alignment and get your wheels balanced...
CLICK HERE!!!
Old 08-20-2007, 10:09 PM   #6
burnsauto
burnsauto's Avatar
could be suspension or steering, could be the alignment, bent wheel/wheel out of balance, wheel bearing....
i'd jack up the front end (rested on jackstands, not just a jack alone) and give everything the once over.
Old 08-20-2007, 10:35 PM   #7
TheTimanator
TheTimanator's Avatar
x2 that'll either fix your issue or tell you what you need to do to fix the vibration
Old 08-20-2007, 10:38 PM   #8
StaticX27
StaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond repute
Could be a bent rim
StaticX27 is offline   Reply With Quote
Old 08-21-2007, 12:19 AM   #9
dued
dued's Avatar
I can't believe I forgot to mention that I had a really good alignment on it also, after repairs. I have also tested car with even tire pressure, slight improvement. I was thinking suspension damage?
Old 08-21-2007, 12:25 AM   #10
sneakerjunkie
sneakerjunkie is making a name for him/her selfsneakerjunkie is making a name for him/her self
how much did it cost u to get it pulld bak. cause i need mine pulld bak. so i was jw on idealy wat im lookin at? thanks
sneakerjunkie is offline   Reply With Quote
Old 08-21-2007, 04:41 AM   #11
streetborotougepimp
streetborotougepimp's Avatar
streetborotougepimp is making a name for him/her selfstreetborotougepimp is making a name for him/her self
X3. if the vibration goes away then its in the wheel. get them balanced. Im almost willing to bet money the vibration goes away. if not then you got a bent wheel.
streetborotougepimp is offline   Reply With Quote
Old 08-21-2007, 04:58 AM   #12
Gumballf355
Gumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to behold
Send a message via AIM to Gumballf355
Just try rebalancing your front wheels first.
Gumballf355 is offline   Reply With Quote
Old 08-23-2007, 12:39 AM   #13
dued
dued's Avatar
cost $2000 for parts and paint
