Old 09-04-2002, 01:54 PM   #1
YellwMonky
YellwMonky's Avatar
YellwMonky is an unknown quantity at this point
When I lock my door from my driver side the passenger side locks too like usual. However, when I try to unlock the door there is no response on the passenger side. This just happened out of no where yesterday. I'm thinking maybe it was too hot. Anybody know what the problem could be? Anybody out there experience this also?
s13 92 White 240sx SE Coupe
YellwMonky is offline   Reply With Quote
Old 09-04-2002, 04:51 PM   #2
icer
icer is an unknown quantity at this point
the only time my car does that is if somebody is holding the passenger door handle while i try unlocking the door.
icer is offline   Reply With Quote
Old 09-04-2002, 04:56 PM   #3
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
I had the same problem with my old S13. The passenger door wouldn't respond to locking, but would respond to unlocking from the driver's side.
I thought it was just a short in the circuit somewhere. I'm not sure if there is a separate fuse for the unlock option. I don't have a solution for you,  so my post is completely useless. I'm a waste of cyberspace.
S13Grl is offline   Reply With Quote
Old 03-25-2003, 10:55 PM   #4
paradoxRPS13
paradoxRPS13 is an unknown quantity at this point
Send a message via Yahoo to paradoxRPS13
Mine started doing this same thing 2 days ago. Does anyone have an answer? My drivers door lock will lock the passenger door but not unlock it. It looks like it moves the lever slightly. I am wondering if I need to get in there with some oil and lube it up? Please help!
Check out my Indiana Drifting website indianadrifting dot com
Gregg
paradoxRPS13 is offline   Reply With Quote
Old 03-26-2003, 10:56 PM   #5
paradoxRPS13
Can anyone help? Please?
Gregg
Old 03-26-2003, 11:55 PM   #6
saliva420
saliva420 is an unknown quantity at this point
i just had that problem fixed, but with the driver side door. i would lock it then unlock it with the power lock but wouldnt be able to open it on the inside. i had the dealer check it out and it was the lock actuator. that may be the same problem with your door. hope that helps.
saliva420 is offline   Reply With Quote
Old 03-27-2003, 07:21 AM   #7
paradoxRPS13
Gregg
Old 03-27-2003, 08:08 PM   #8
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
I looks like the post above yours has a possible solution. You may want to check it out..........Here's the post in case you didn't read it this time...........
Lauren
'91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq
'94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq
'00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300)
Green Country Motorsports
Northeastern Oklahoma SCCA
96SEChick is offline   Reply With Quote
