Old 09-03-2002, 10:38 PM   #1
philipwight
philipwight is an unknown quantity at this point
I bought a vlsd from jspec.com and was wondering how i can find out what the gear ratio is,  i dont want to try and count the teeth.  Some of the numbers on the differential are
A5-9500330b and right under that is 19768. Its looks as though those were printed on there some how.
these are casted into the housing:
68311
40F00
This looks as if it was stamped on there:
331B
A5
any help would be much appreciated.
philip
1993 Nissan 240sx
-KAAZ 2-way
-crystal clear H4 upgraded lights
-sportline springs-tokico blue struts
-(1)JL audio 12w3 in bandpass box-Rockford 500x-Infinity 4x6
-clarion Rdx765Dz head unit
philipwight is offline
Old 09-03-2002, 11:23 PM   #2
guidot
guidot is an unknown quantity at this point
Send a message via AIM to guidot
Is it an aftermarket vlsd or is it a OEM part?  The OEM part is ~4.09 ratio.  Fairly high if you analyze it.  If its aftermarket I would try to contact the company about it.
-Jeff T. 96 240SX
240SXONE
http://www.240sxone.com
guidot is offline
Old 09-03-2002, 11:28 PM   #3
philipwight
I belive it is an oem part, but it is from japan so i think it may have come off of a turbo s13, which i belive have lower gear ratios.
1993 Nissan 240sx
-KAAZ 2-way
Old 09-03-2002, 11:34 PM   #4
guidot
Well I really cant answer your question properly if you already know it.  I know the transmission gear ratios didn't change, so why would they change the rear end ratios, I don't know.
-Jeff T. 96 240SX
240SXONE
guidot is offline
Old 09-04-2002, 10:04 AM   #5
AKADriver
AKADriver's Avatar
It's either 4.083:1 (KA24DE, SR20DE, SR20DET manual) or 3.916:1 (SR20DET automatic), most likely.  There's a smaller chance it's a 4.363:1 unit from a CA18DET.
If you don't mind opening up the diff, you don't have to count the teeth...  IIRC there should be a set of numbers stamped on the ring gear itself.
49/12 = 4.083:1
47/12 = 3.916:1
48/11 = 4.363:1
AKADriver is offline
Old 09-04-2002, 11:50 AM   #6
philipwight
thank you for the information, that was exactly what i was looking for, it is 4.083 gear ratio.
1993 Nissan 240sx
-KAAZ 2-way
Old 09-18-2002, 04:50 PM   #7
exitsanity
exitsanity is an unknown quantity at this point
so the higher gear ratio is the more desireable one?
'01 Nissan Sentra SE (sr20de) for sale
'91 Nissan 240sx fastback (ka24de) being built
.my website.
exitsanity is offline
Old 10-02-2002, 09:29 AM   #8
Phlip
Yes, I look like that
Phlip's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (exitsanity @ Sep. 18 2002,5:50)</td></tr><tr><td id="QUOTE">so the higher gear ratio is the more desireable one?</td></tr></table><span id='postcolor'>
The higher the number, the shorter the gear, the sooner you will have to shift... I know someone with the 4.36 and he has virtually NO use for 1st gear before he redlines and has to shift. This being said, you will get worse gas mileage the shorter that gear is.
Weirdo
And I write too!
Phlip is offline
Old 10-02-2002, 10:03 AM   #9
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (guidot @ Sep. 04 2002,02:34)</td></tr><tr><td id="QUOTE">Well I really cant answer your question properly if you already know it. I know the transmission gear ratios didn't change, so why would they change the rear end ratios, I don't know.</td></tr></table><span id='postcolor'>
Guidot,
SR20DET motors in Japan will have a lower final drive ratio, as was explained in the 2 posts above mine, because you can stay in that gear longer.
Normally, that's not good, but when you are boosting, you would like to stay in the spool-up area for as long as humanly possible. &nbsp;That's why. &nbsp;Same with 300zx NA vs. TT. &nbsp;The NA has our gear ratio, while the TT has 3.8something.
-Jeff
Whatup?
Jeff240sx is offline
Old 10-02-2002, 11:38 AM   #10
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">It's either 4.083:1 (KA24DE, SR20DE, SR20DET manual) or 3.916:1 (SR20DET automatic), most likely. There's a smaller chance it's a 4.363:1 unit from a CA18DET.
49/12 = 4.083:1
47/12 = 3.916:1
48/11 = 4.363:1
ok this correct to a point.
The SR powered Turbo cars i.e. S14 and S15 came with 3.70:1 gears . I also am pretty sure it was the same with the S13 SR20DET cars . The 300zx TT &nbsp;also came with 3.70:1 gears .
as far as the CA18det ratio's are concerned you are correct
New Video
Buy my mounts!
drift freaq is offline
Old 10-02-2002, 01:46 PM   #11
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
Send a message via AIM to Grant Send a message via MSN to Grant
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (drift freaq @ Oct. 02 2002,10:38)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">It's either 4.083:1 (KA24DE, SR20DE, SR20DET manual) or 3.916:1 (SR20DET automatic), most likely. There's a smaller chance it's a 4.363:1 unit from a CA18DET.
49/12 = 4.083:1
47/12 = 3.916:1
48/11 = 4.363:1
The SR powered Turbo cars i.e. S14 and S15 came with 3.70:1 gears . I also am pretty sure it was the same with the S13 SR20DET cars . The 300zx TT also came with 3.70:1 gears .
as far as the CA18det ratio's are concerned you are correct</td></tr></table><span id='postcolor'>
according to Sam from jspec.com the s14 silvia LSD differential &nbsp;had the 3.92:1 gear ratio. He indicated to something on the casing of the diff itself referring to that.
Grant is offline
Old 10-02-2002, 01:52 PM   #12
sayuki
sayuki's Avatar
sayuki is an unknown quantity at this point
Send a message via AIM to sayuki
hmm - would this also explain why I can't put her into 1st gear unless I am going so slow I'm practically stopped?
sayuki is offline
Old 10-02-2002, 10:47 PM   #13
drift freaq
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">according to Sam from jspec.com the s14 silvia LSD differential had the 3.92:1 gear ratio. He indicated to something on the casing of the diff itself referring to that.
well it may have come in some of the cars but the info I had came straight from a ziliva member who lives in UK because I wanted to know and asked and he answered right out of his FSM.
New Video
Buy my mounts!
