Old 09-12-2007, 11:29 PM   #1
alex dee
alex dee is an unknown quantity at this point
rb20 in s13
serious sic of this garbage i have been tryin to get my rb20det running for months but everytime i goto crank the car the computer power shuts off(i know this but the little red light on the ecu) mind u though i have fule pump ,computer power, starter,
and rad fan all on toggle switches i have a feeling that the computer needs a certain voltage anyone who every put a rb20 in a s13 i need your help the car is all done now except this shit
alex dee is offline   Reply With Quote
Old 09-12-2007, 11:34 PM   #2
bardabe
bardabe's Avatar
u still need to power ignition, and give the computer the start signal.
Review Thread
bardabe is offline   Reply With Quote
Old 09-13-2007, 01:30 AM   #3
Yellow4g63
Doing the RB20 swap in a S13 was cake for me (4 years ago lol). I even used the RB lower harness. Maybe you should send the harness out to someone to do for you and look for another ecu. Check racebread.com for info on the wiring. I followed the steps by CarlH and mine fired right up.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 09-13-2007, 05:54 AM   #4
alex dee
can all thoses three wires run off 12 volts?
Old 09-13-2007, 09:06 AM   #5
Yellow4g63
Sorry I can't spoon feed you since I haven't done it in a long time. Unhook all your wiring and start over.
http://www.racebread.com/old/Documen...ou%20wanna.doc
http://www.racebread.com/old/Documen...Skillzilla.doc
91 Nx2000 VVL yo
Old 09-13-2007, 10:25 AM   #6
bardabe
bardabe's Avatar
not the same source, the Ignition It's own toggle switch, and the start signal suppose to get spliced into the Ignition Switch "Start" 12V
check out the write ups he liked you to. they should clear things up for you
Review Thread
Old 09-13-2007, 05:13 PM   #7
alex dee
ok ok heres what i did(rember that computer power and starter are off toggle switches) i wired the the ignition relay to the starter (like instructed) when i say starter i mean the starter signal wire (skiny wire) then the the ecu memory and ignition power to a 12V SOURSE now when i go crank my car the computer still turns off
i honestly truly appreciate any help thank you very much
Old 09-13-2007, 05:44 PM   #8
bardabe
bardabe's Avatar
its kinda hard to explain to you what to do with electrical, I rewired my car from scratch and did a similar set up to yours exept Im using the OEM Ignition switch with push start. look at my Chassis rewiring thread i have the wiring diagrams right there.
Review Thread
Old 09-14-2007, 07:46 AM   #9
alex dee
where that threAD?
Old 09-14-2007, 10:06 AM   #10
bardabe
bardabe's Avatar
http://www.zilvia.net/f/showthread.php?t=140596
try using seatch next time alright. if u keep doing this you will get flamed allot. only reason they dun do it now. cause well RB isn;t the specialty on zilvia but we have quite a few people with RB.
Review Thread
