Old 09-17-2007, 09:31 AM   #1
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
T25 outlet gasket - Using gasket maker?
I'm trying *really* hard to find an OEM 5-hole outlet gasket for my SR's T25 before Wednesday, when I'm installing a high flow O2 housing, and simply can't. Not without paying $40 for overnight shipping
Is there a silicone (or other) gasket maker that would do the job? I'm not too optimistic since it would have to deal with some serious heat, but >$50 is a lot to pay for one little gasket
SHIFT_*grind* is offline   Reply With Quote
Old 09-17-2007, 10:30 AM   #2
Sileighty_85
Sileighty_85's Avatar
No way dude that sh*t will blow out in no time.
its the Same gasket as the Z32TT Turbos
Try Autozone
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-17-2007, 03:29 PM   #3
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
www.courtesyparts.com
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 09-18-2007, 08:55 AM   #4
SHIFT_*grind*
Yeah, that's what I figured. By the time I discovered I couldn't find a gasket locally, it was too late to order it and be sure that it would get here in time (even with overnight shipping).
I didn't realize until now that, since it's metal and not paper, it should be OK to re-use, so I'm just gonna do that for the time being. Maybe replace it in the near future.
