Old 09-20-2007, 02:36 AM   #1
chillinpinoy
chillinpinoy is an unknown quantity at this point
help with suspension
hello! i was wondering if anyone can help me out with a problem i have with my suspension. the holes where you insert the bolt to attach the brake system to the shock won't align. is there a way i can align it so i can insert the bolts or do i have to go out and buy new shocks? i don't know if that sounds right. but any suggestions would be great.
chillinpinoy is offline   Reply With Quote
Old 09-20-2007, 08:28 AM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
yes turn it or push the rotor down to make it fit. if its the rear push the rotor down it should fit. unless you didnt put the shocks/ struts on right. fix it
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 09-20-2007, 08:41 AM   #3
chester_ff7
chester_ff7's Avatar
chester_ff7 will become famous soon enoughchester_ff7 will become famous soon enoughchester_ff7 will become famous soon enough
Send a message via AIM to chester_ff7
just move it up and down, back and forward...(the rotor).... it will go in... if all else fails have a buddy help you move the rotor while you try and get the screws in...
chester_ff7 is offline   Reply With Quote
Old 09-20-2007, 10:29 AM   #4
aznpoopy
aznpoopy's Avatar
if its too low and shock is too high (common with coilovers), just jack it up
if its vice versa, stomp on it a few times
aznpoopy is offline   Reply With Quote
Old 09-20-2007, 04:42 PM   #5
chillinpinoy
i tried pushing down the rotor and i'm still a few inches shy of inserting the screw. i did it before but idk why it just won't align this time.
