running issues with ca poweredsilvia
The last time i was on here i owned a 240 droptop with sr swap. got into a little accident which totalled her. Now i own a rhd 89 silvia k with ca18det. anyway i have a good list of mods on it. but when i put on the ka24e throttle body i found that i gained an issue. the vehicle has a very rough start up. like it has a hard time cranking over then when it does start it runs rough with rpm's around 1500. it takes about 5 minutes for it to warm up and then runn kinda normal. but rpm's fluctuate. do you think it's a problem with my tps or maybe even the throttle body itself? i'm baffled. i'm gonna try resetting the safc and see if that helps (helped someone else before) . any help is greatly appreciated
Aeromotive A1000-6 FPR Nismo fuel rail adapter Nismo Big operating cylinder (clutch slave cylinder) Nismo clutch fork pivot Zoom Stage 3 clutch and pressure plate (6 puck sprung) JUN 5.4kg lightweight flywheel JIC SF-1 coilovers KA24E 60mm throttle body Energy Suspension master bushing kit Billet aluminum slotted subframe collars S14 hard tie rods inner and outer set Billet aluminum waterpump, alternator and power steering pullies RAYS 17X7.5 Gram Lights 57S 215/45/17 Falken GR Beta FK451 tires 3" Turbo back exhaust Blitz BOV HKS Power Filter MOMO steering wheel Blitz boost gauge chipped ecu Nismo short shifter Trust Shift knob turbo timer Endless pads and Slotted Rotors Apexi S-AFC 2 Walbro 255LPH fuel pump RB26DETT MAFS (80mm) NGK spark plugs (1 heat range colder-BKR7E) HKS oil cap 440cc DSM injectors Greddy R-SPL Type 6 FMIC kit(10"X10"X4") Greddy VVC boost controller HKS GT2530R turbo .64 A/R Koyo OEM rad Dual Altima fans and ajdustable fan controller HKS Step 1 256IN/264EX cams |
