Old 09-21-2007, 08:41 PM   #1
onehalfasia
onehalfasia is making a name for him/her selfonehalfasia is making a name for him/her self
Did I install my clutch backwards :Video: ?
Clutch newly installed and the fork only moves till the pressure plate teeth(1/2 way), then I'm not able to move it farther. Is this normal? I want to make sure before installing my engine.
http://s128.photobucket.com/albums/p...t=MVI_0928.flv
onehalfasia is offline   Reply With Quote
Old 09-21-2007, 08:48 PM   #2
johngriff
johngriff's Avatar
Yeah, its a bitch to push the fork by hand, bolt the slave cylinder up and try it with the pedal.
[email protected]
Old 09-21-2007, 08:51 PM   #3
onehalfasia
cool thanks, so then its probably right...time to install the motor
Old 09-21-2007, 11:14 PM   #4
Vision Garage
Vision Garage's Avatar
Vision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfection
Send a message via AIM to Vision Garage
yup John is rite. Unless you are hercules you arent moving that fork. Put in the slave and bleed it. You may have to pump the slave with your hand a bit if the prong doesnt reach the fork.
Vision Garage is offline   Reply With Quote
