Old 09-23-2007, 12:34 AM   #1
supermariokartdrift
supermariokartdrift's Avatar
supermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymoresupermariokartdrift is not welcome here anymore
Rear 300zxtt rear on 240sx
I heard that the rear hubs from a 300zxtt are a little different and would work on a 240sx on a 300zx rear caliper upgrade, but the non turbo hubs are identical to s13 . Would any of these hubs work on the rear uprights. are non turbo and turbo uprights the same? Does any one know?
supermariokartdrift is offline   Reply With Quote
Old 09-23-2007, 01:20 AM   #2
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
will they work?
z32 NA - yes - aside from the 5 lug, they are the same
z32 TT - no - spline size is larger
the uprights are the same except the TT has a ball joint instead of a bushing on the toe rod connection. you can press it out and put in the right bushings, but you're better off just getting a whole NA knuckle and throwing the whole thing on.
cdlong is offline   Reply With Quote
