Old 09-23-2007, 01:22 AM   #1
primerprincess
primerprincess has a little shameless behavior in the past
Need Help--Strange Problem
Hey, I need help again. My 95 KA started to shut off on me while driving--no warning or anything. I would have to let it sit and then start it and get it home. Got it scanned and code said that I needed a knock sensor, so I replaced that. Now it scans clean, but now there is a starting problem. The car will start just fine, but only stays running for about a second and then shuts off. Spark is fine, seems to be getting gas no problem, so I am lost. I really want my car back, so I will appreciate any help you guys can give me. Thanks!!
primerprincess is offline   Reply With Quote
Old 09-23-2007, 10:34 AM   #2
95Kouki
95Kouki's Avatar
95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough
did you recently have any work performed on the car (motor or chassis?)
did you recently was under the engine bay or have a huge amount of rain lately?
to me it sounds as if you're having problems with your TPS/idle adjustment...check using the procedure outlined in the FSM and make adjustments or replace as necessary.
also don't rule out a coolant temp sending unit or MAF...
Best of Luck
Jason
People will always be haters...can't change that...just out drive them
95Kouki is offline   Reply With Quote
Old 09-23-2007, 11:33 AM   #3
SlidewayzS14
SlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymore
i had this problem on my old acura. It turned out to be the Ignition switch. Might not be your problem, but worth a look.
SlidewayzS14 is offline   Reply With Quote
Old 09-25-2007, 04:29 AM   #4
s13monkey
s13monkey's Avatar
s13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to behold
Send a message via AIM to s13monkey Send a message via Yahoo to s13monkey
check your pcv valve if you follow the house that comes from your brake booster you'll see a small valve check itand the hoses that go to and from the booster to pcv to intake manifold.
s13monkey is offline   Reply With Quote
