Old 09-23-2007, 05:02 PM   #1
greencoupe
greencoupe can only hope to improve
Send a message via AIM to greencoupe
FS: 1989 240sx coupe: silvia front, redtop sr20det etc...cheap!
**Posting for a friend, his contact info is in the post***
i recently aquired this car, however i've decided that i can't handle two major project cars, this is my least favorite so its got to go.
with that said:
-1989 nissan 240sx coupe
-sr20det redtop (with distributor ignition)
-silvia brick headlight front end with aero bumper
SR20:
when i got the car it ran and drove, but had no power and smoked horribly bad, a compression test showed no compression at all in cylinder number 1
discovering this, i pulled the engine and removed the head...
the head looks to be fine and in good shape as well as cams, rockers etc...
however the bottom end doesn't look so good, the piston in cylinder one is missing a portion, and the others dont look so good either. it does look like a simple bore and replacing of the pistons should repair the engine.
***the engine is currently not in the car and in pieces***
the car is also run on a distributor, and not coil packs. i cannot figure out a reasonable reason for this but it obviously works as the car did run fine until the guy i bought it from pulled the wastegate line and overboosted the engine.
MOD LIST:
RPS clutch
koyo rad
large FMIC
HKS SSQV
D2 Coilovers
full 3" turbo back RSR exhaust
rear five lug conversion
greddy turbo timer
apexi rev speed meter
phantom boost gauge
jim wolfe ecu, tuned for the lightly modded sr20
simple mods:
silvia trunk badge around the key
silvia floor mats
s14 seats
17" wheels on the five lug rear
probably many other things that ive missed...
other issues:
the car needs a paint job badly
the engine does need repaired and re-installed
(not that it would make any sense,but i can put the engine back in as is and sell the car running like crap and smoking badly)
Contact me :
[email protected]
717-271-8781
aim: cocalicorunner
pics:
Price:
3500 neg.
****if the car does not sell soon, i may be willing to part it out. i can also consider selling some of the parts separately.
i do have the CLEAN title in hand, i have not carfaxed it but the title has no brandings on it.
thanks for looking,
-Jason
greencoupe is offline   Reply With Quote
