Old 09-28-2007, 04:11 PM   #1
DOOK
DOOK's Avatar
Help Diagnose my Problem....
Well well well.... of fucking course more issues with the SR... so after getting a new battery, I hook it up and crank the car over... after about half a crank I get the seized, THUD from the motor. I'm like, fuck... so I pull the coilpacks and plugs, crank her over again and make another gasoline fountain, only this time it wasn't just out of the number 2 cylinder, it was out of ALL FOUR... so I'm like shit, so I unhook the injectors, crank that bitch over again and same thing, gasoline fountain, I think to myself, it'll dry up in a minute, but not, it just kept flowing... Then I got to thinking, that's a lot of fucking gas, which it was. I'm at a loss as to what would cause my cylinders to fill with gas so quick as to not let the engine crank over.... HELP
<------ Grumpy Old Asshole
DOOK is offline   Reply With Quote
Old 09-28-2007, 04:25 PM   #2
SiI40sx
SiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfection
Send a message via AIM to SiI40sx
have you tried checking for spark? seems like everything is working but nothing is sparking (bad plugs bad coilpacks bad ignitor bad ecu) start a check list
SiI40sx is offline   Reply With Quote
Old 09-28-2007, 04:29 PM   #3
DOOK
DOOK's Avatar
never got to spark... I mean it's not even getting a whole crank over before the cylinder is seized full of gas... how much gasoline are the injectors supposed to put out normally... I'm not kidding when I say I had a fountain of gas in my garage.
Old 09-28-2007, 05:30 PM   #4
DOOK
DOOK's Avatar
help me anyone who has ANY idea, can the injectors really put out enough fuel that quickly to seize the motor without spark in half a second????
Old 09-28-2007, 06:11 PM   #5
junkey311
junkey311's Avatar
junkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymore
try disconnecting the fuel pump completely. if the engine still doesnt crank, without fuel, then there is another problem at hand.
junkey311 is offline   Reply With Quote
Old 09-28-2007, 06:14 PM   #6
johngriff
johngriff's Avatar
Injectors are F'd, or the o rings, but you a dumping fuel w/o an injector pulse.
As well, if it cranked then STOPPED.
Congrats.
You have hydroloc'd the motor.
Get all the gas out, do a compression test, more than likely you bent the valves on that one.
[email protected]
Old 09-28-2007, 06:49 PM   #7
DOOK
DOOK's Avatar
you think in 1/2 a crank?
Old 09-28-2007, 07:08 PM   #8
johngriff
johngriff's Avatar
it just compressed a bunch of liquid towards open valves and seized, it doesn't sound good.
But, check the COMPRESSION FIRST.
[email protected]
Old 09-28-2007, 07:38 PM   #9
DOOK
DOOK's Avatar
alright, would the ground and power wires being hooked up backwards on the injectors cause this problem????? I just want to get it running so I can get rid of it. This car is making me hate nissans.
Old 09-29-2007, 10:29 AM   #10
DOOK
DOOK's Avatar
talked to a local mechanic this morning who has a little experience with our common rail side feed injector setups and he seems to think the injectors are seized and may be freed up with a little pecking, so I'm gonna try it and see. After I get the injectors figured out I'll do a compression test.
Old 10-03-2007, 08:03 AM   #11
cronux
cronux's Avatar
cronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to all
dude, check the lower o-rings, because if they are ripped, then fuel rushes into the cylinder.
cronux is offline   Reply With Quote
Old 10-03-2007, 12:10 PM   #12
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
but not at the rate that it would stop rotation of the crank. John is correct, it sounds to me like the injectors are flowing as a constant open.
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 10-03-2007, 12:19 PM   #13
drifting_changed_mylife
drifting_changed_mylife's Avatar
drifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymore
Send a message via AIM to drifting_changed_mylife
i had a similar problem and it turned out to be the spark. so i changed the cas, spark plugs, and reset the timing with the cas. but still way to much fuel. then it turned out to be a bad ground that was making the car spark weak. so i changed the engine ground cable to a thicker one and the car runs like a dime
btw good luck man
your neg reps match my avitar.... keep em commin
drifting_changed_mylife is offline   Reply With Quote
Old 10-03-2007, 01:16 PM   #14
daryl337
daryl337's Avatar
that will cause excessive fuel, but once again, it should not cause enough to stop your engine from cranking due to large amounts of fluids in the cylinders... since the engine would pump most of the vapors out, but if there is so much fuel in your cylinders that the pistons cant even pump it out, you have a major malfunction of the injectors.
Old 10-03-2007, 02:54 PM   #15
trmn8r
trmn8r's Avatar
trmn8r is an unknown quantity at this point
hope you didnt hydrolock the engine man. that thump isnt good.
oh yah! its el nismo
trmn8r is offline   Reply With Quote
Old 10-19-2007, 08:51 AM   #16
DOOK
DOOK's Avatar
we will see, I'm doing a compression test tonight.
Old 10-19-2007, 09:43 AM   #17
steve shadows
steve shadows's Avatar
and your a premie too...sigh
1. take out the coil packs
2. take off the fuel rail
3. take out the spark plugs
4. take a hanger and tape a small peice of cloth to it.
5. TIGHTLY, and then dip it into each cylinder
6. if its not soaked in gas then your not hydrolocked
7. make sure you do what I just said after it thuds.
Like Me on FaceBook !
Old 10-19-2007, 09:57 AM   #18
DOOK
DOOK's Avatar
well it's not hydrolocked now, I know that. I also know that it was, but I cut the fuel and blew all the gas out, now I just have to see if any damage was caused (I.E. bent valves, etc) before I go and start diagnosing WHY it happened in the first place.
Old 10-19-2007, 10:28 AM   #19
Antihero983
Antihero983's Avatar
hmmm.....what about the FPR? could it not be properly regulating, and allowing too much fuel to flow?
Old 10-19-2007, 12:26 PM   #20
tiresmokes13
Banned from the Marketplace
tiresmokes13's Avatar
tiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond reputetiresmokes13 has a reputation beyond repute
Pull out all of your injectors and check the O rings.
tiresmokes13 is offline   Reply With Quote
Old 10-19-2007, 03:05 PM   #21
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
O RINGS!!!! i thought that at first and its been said a million times! the lower guys
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline   Reply With Quote
Old 10-19-2007, 03:43 PM   #22
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
you WILL NOT bend the valves from a hydrolock. Worst case is bent rods. But since the motor didnt spin very quickly i doubt that happend. Just remove the rail and turn the key to on. There should be no fuel coming out anywhere
RedtopTech is offline   Reply With Quote
Old 10-19-2007, 04:28 PM   #23
DOOK
DOOK's Avatar
this is getting done tonight after the compression test assuming compression is fine so I can see what injector/injectors are feeding fuel... if it's all of them I'm testing the ECU first and take it from there. Thanks a ton.
