Old 09-29-2007, 03:29 AM   #1
BillyTheChamp
BillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the roughBillyTheChamp is a jewel in the rough
crazy temp gauge..
i was just curious if my thermostat was going bad.. when i floor my car my temp gauge goes down to cold.. then back up to the middle when i let go.. anyone else have this issue? any recommendations?
BillyTheChamp is offline   Reply With Quote
Old 09-29-2007, 03:43 AM   #2
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
stock guage or aftermarket? stock location of temp sensor or on top rad hose?
come on you need to put a little more info if you want some sort of help
CKAMC is offline   Reply With Quote
Old 09-29-2007, 09:15 AM   #3
mizono
mizono is making a name for him/her selfmizono is making a name for him/her selfmizono is making a name for him/her self
Its the temp. sensor for the oem gauges, its going bad. This is a common problem. The motor has two coolant temp sensors one for the gauge and one for the ecu.
mizono is offline   Reply With Quote
Old 09-29-2007, 09:40 AM   #4
all stock
all stock is on the path to ruinall stock is on the path to ruin
does it drop down fast or does it go down slow? i've had similar problems after getting an aftermarket radiator. replaced thermostat, no problem after.
could be sensor if the needle plummets quickly.
NASA PTD/SCCA ITS
all stock is offline   Reply With Quote
Old 09-29-2007, 10:24 AM   #5
BillyTheChamp
yeah it's the stock gauge.. and i do have a koyo allum.. it does drop down fast when i floor the gas or when it builds up boost, so should i replace my thermostat with an aftermarket one or will a stock one be fine?
Old 09-29-2007, 10:27 AM   #6
D1GP
D1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the rough
stock one is fine. check your overflow bottle as well and make sure there are no cracks.
D1GP is offline   Reply With Quote
