Old 10-08-2007, 07:25 PM   #1
SSMini
SSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the roughSSMini is a jewel in the rough
Need a little help on the Z32 brake conversion.
Picked up a few parts off a 1990 300ZX NA. Picked up the Master brake cylinder, front rotors (Front calipers were already gone.), and the complete rear brake assembly. (Rotors, calipers, dust shield, 5 lug hub, ect, ect.) Did not get the e-brake line. Some questions I have are:
*Can I use the 30mm Front caliper with the 26mm rotor?
*Besides the e-brake lines and brake lines, do I need anything else to install the rear set up?
*I've read that some people use a E-brake line extension to use the factory 240 e-brake line. Is this true? If so, where can I pick this part up?
Im installing this on my 93 s13
I found a few links on the conversion, read all that I could find, but there are some questions I still have. If you have some links that may be helpful, please share...Need all I can get on the s13 front 5 lug conversion portion.
Thanks...
SSMini is offline   Reply With Quote
Old 10-08-2007, 07:32 PM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
1. no you cant use the 26mm
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 10-08-2007, 07:53 PM   #3
SSMini
Thanks for your help/reply. I guess I'll have to take back the 280mm x 26mm rotors back and find some 280mm x 30mm rotors to use with the 30mm calipers. I guess the 30mm calipers are easer to find then the 26mm since the 26mm only came on the 1990 300zx. So, to add to my shopping list:
*30mm Calipers
*280mm x 30mm rotors
Thanks again....
