Old 10-09-2007, 07:40 PM   #1
attracted
attracted's Avatar
attracted is making a name for him/her selfattracted is making a name for him/her self
300zx subframe in s13
has anyone done a 300zx subframe swap on a s13
if so any pics of how u guys did it and or finished product
attracted is offline   Reply With Quote
Old 10-09-2007, 08:04 PM   #2
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
No... It's wider and won't fit...
Nikeboy355 is offline   Reply With Quote
Old 10-09-2007, 08:28 PM   #3
attracted
attracted's Avatar
ok first of all it does fit u just gotta move the studs around
no2 that is the reason why u would already want to put a 300zx subframe its because it wider ...bigger stance...
ive seen it done..just never seen the under fnished job...thats why i was inquiring
Old 10-09-2007, 08:45 PM   #4
projectRDM
projectRDM's Avatar
'Fit' is a very loose term. With enough work anything will fit, but why? Yes, it does fit if you either remove the subframe bushings completely and produce offset bushings which ride up against the subframe's collars, or cut the mounting studs off, drill/tap an inch further out, and use new mounting bolts from the bottom and hope like hell the rear crossbox doesn't tear out.
Either method involves a load of custom fabrication and the benefits are absolutely pointless, especially when you can mount wider wheels or use spacers. The Z32 subframe itself is no better or stronger than what you have.
FORMERLY R240NA
