Old 10-14-2007, 08:11 PM   #1
Seven
Seven is making a name for him/her selfSeven is making a name for him/her self
Send a message via AIM to Seven
Power window issues...
So the car I bought (an S14) has power windows but they don't work.
Everything mechanically seems to be intact, wiring looks good too (no frayed wiring). The previous owner said it needs an amplifier for the switch. I've never heard of an amplifier for a window switch personally but I've never had a power window issues before anyways.
What's the most common thing to go wrong with the power windows on the S14s and what most likely to fix it?
Thanks
Seven is offline   Reply With Quote
Old 10-14-2007, 08:19 PM   #2
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
The amp is the most common thing to go bad. Its a small white box located in the door. I will find a pic....http://www.zilvia.net/f/showthread.php?t=160297
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
Old 10-14-2007, 08:34 PM   #3
Seven
Just to cover this I wanna ask.
if that is bad will both windows not work.
I can't roll either window up or down (can't even roll the pass side window down with the pass side switch).
Old 10-14-2007, 08:37 PM   #4
s13rookie
s13rookie's Avatar
well, the pass window does not have an amp. If neither windows work than it may be your window switch
Old 10-14-2007, 08:43 PM   #5
Seven
Ok cool, thanks. Whats the story on that, tho? Location?
Old 10-14-2007, 08:48 PM   #6
s13rookie
s13rookie's Avatar
I meant the window switch on the door itself. Will your pass window roll up with the pass. door switch?
Old 10-14-2007, 08:51 PM   #7
Seven
Oh ok...
and no it won't.
I was wondering if the driver's side controls go bad if it'll cause the pass side controls to fail too.
Old 10-14-2007, 08:54 PM   #8
s13rookie
s13rookie's Avatar
hmm, Im sure the car only has 1 amp thats mounted in the drivers door, but i cant remember if that amp runs both windows, or just the drivers. Its been a while since ive screwed with a window.
May want to wait for someone more familiar with those issues
Old 10-14-2007, 08:56 PM   #9
Seven
Ok then, Thanks sir!
If someone chimes in then great, if not, then I figure I'll drop the cash on a switch AND an amp, put one in at a time. See which I needed and then keep the other for a spare OR, just sell it on the classifieds, help out someone.
Old 10-15-2007, 08:00 AM   #10
projectRDM
projectRDM's Avatar
Amplifier only drives the driver side window, and it's only found on 95 models.
Do this, check the motors first with a battery to make sure they work. If they're good, move on the diagnosing the switch per the FSM, check for power and ground to the switch and output for both sides. It's stupid to buy parts and hope you'd found the solution when you can properly diagnose it with a multimeter and know for sure.
FORMERLY R240NA
Old 10-15-2007, 10:03 AM   #11
Seven
I do have a 95. But I suppose I'll be buying a multimeter this week then.
Old 10-15-2007, 10:07 AM   #12
axiomatik
axiomatik's Avatar
good idea. a multimeter is an indispensible tool.
Old 10-15-2007, 02:42 PM   #13
ThePenIsMightier
ThePenIsMightier is not welcome here anymoreThePenIsMightier is not welcome here anymoreThePenIsMightier is not welcome here anymoreThePenIsMightier is not welcome here anymoreThePenIsMightier is not welcome here anymoreThePenIsMightier is not welcome here anymoreThePenIsMightier is not welcome here anymoreThePenIsMightier is not welcome here anymoreThePenIsMightier is not welcome here anymore
Pull out the regulator behind the door panel. It is in a little off white rectangle box. Pull out the circuit board and look on the back. You may have some worn spots on the board. Solder them up and you're good.
ThePenIsMightier is offline   Reply With Quote
Old 10-15-2007, 03:29 PM   #14
projectRDM
projectRDM's Avatar
That is the amplifier, not the regulator. Please don't confuse the situation any more than it needs to be.
FORMERLY R240NA
Old 10-23-2007, 04:06 PM   #15
domo dorigato
domo dorigato is an unknown quantity at this point
Send a message via AIM to domo dorigato
R240NA, i have to ask since you know a lot about the subject. I am having a hard time trying to find the 96 window switch with the amp.
I see a lot of 94, 95 and maybe some 97 here and there (master power window switches). They all have different pin counts in the back.
Will either one work?
the 94-95 is a 11-pin. the 96 is a 12-pin and the 97 is a 10-pin.
domo dorigato is offline   Reply With Quote
Old 10-23-2007, 06:38 PM   #16
projectRDM
projectRDM's Avatar
Incorrect info. The 96-98 switches are all the same. I've swapped plenty of them back and forth. Only the 1995 model is different.
1994 is the S13 chassis, not even remotely close to working.
FORMERLY R240NA
