Old 10-16-2007, 08:18 AM   #1
slohybrid
slohybrid's Avatar
slohybrid is an unknown quantity at this point
FS: parting out 91' 240SX hatch SR20DET lots of stuff!!!
I have decided to part out my car. The following items are in almost new condition (LESS THAN 100 MILES ON THE ITEMS):
This stuff comes off of my S13 hatchback:
Chargespeed carbon fiber hood S13 hatch (CF on both sides) w/ hood pins installed--SOLD
345.00--NEW LOWER PRICE
JIC Sparten DE 3” cat-back exhaust
Battle Version rear upper control arms--SOLD
700.00--SHIPPED NEW LOWER PRICE
Power FC w/ hand held commander (MAFS set-up not MAP)
345.00
FC Datalogit w/ USB cable and software
50.00
Tanabe front under brace
280.00--NEW LOWER PRICE
Godspeed bar and plate intercooler kit for a KA24DE top mount w/ extra couplers and clamps
120.00
Aeromotive fuel pressure regulator w/ -6AN fittings and plug
100.00
Apex’I intake filter for Z32 MAFS
Blitz FATT turbo timer w/ P2M turbo harness--SOLD
400.00--NEW LOWER PRICE
Fastbrakes Q45 brake kit (slotted and drilled rotors, stainless steel brake lines, Axxis metal brake pads, Q45 calipers) (4 and 5 lug drilled)
S14 seats (pair)(used in excellent condition)--SOLD
Replacement black carpet hatchback S13 (NEW still in box)--SOLD
Brian Crower 264 cams (set new in box)--SOLD
Nardi Steering Wheel deep corn with Circuit sports quick release and sparco hub--SOLD
Peak Performance inner pro/ and outer street tie rods w/ boots--SOLD
Battle Version tension rods--SOLD
Megan coilovers--SOLD
Whiteline front and rear sway bars w/ links and Whiteline sway bar bushings--SOLD
Peak Boost exhaust manifold (top mount T3 flange), Peak Boost o2 elbow with 3 o2 bungs welded in (one plug, one stock o2 adapter), Peak Boost downpipe, v-band clamp, turbo to manifold gasket, Tial wastegate 38mm with 15# spring--SOLD
GT3076R Garrett turbo w/ ported shroud, heat coating, and polished--SOLD
Driveshaft Shop one piece aluminum driveshaft--SOLD
Koyo aluminum radiator--SOLD
ATI crank damper--SOLD
(4) side feed 1000cc/min. injectors (drop in) (set)--SOLD
(4) side feed 660cc/min. injectors (drop in)(set)--SOLD
Chargespeed carbon fiber S13 hatch headlight covers--SOLD
Aeromotive A1000 fuel pump w/ -10AN and -8AN fittings installed--SOLD
S13 OEM Kouki Type-X front bumper w/ side pieces--SOLD
ARC BOV--SOLD
R33 GTS-T LSD w/ axles (has clutch type LSD in it) already has correct diff. cover for direct bolt on to S13--SOLD
SR20DET motor w/ tranny—SOLD
Fully built SR20DET block by Mazworx--SOLD
It has been sleeved with Golden Eagle ductile iron sleeves 90mm bore--SOLD
O-ringed and comes with stainless steel o-rings (stainless steel wire)--SOLD
oil grooved at the mains
decked with oil pump front cover (included used)--SOLD
macined to accept ½ inch head studs (will include head studs ARP new)--SOLD
(4) CP pistons with rings, lateral gasport, double pin oiler, accumulator grooves, heavy duty wrist pins and locks (set new)--SOLD
(4) Carrilo rods (new)--SOLD
Set of calico coated ACL main bearings and thrust bearings (new)--SOLD
Rear brake calipers--SOLD
OEM side skirts--SOLD
4th Degree Black Belt Hapkido
Skydiver
Got no drifting skills (haven't tried)
slohybrid is offline   Reply With Quote
Old 10-16-2007, 08:44 AM   #2
sukimoto
sukimoto is an unknown quantity at this point
still have the turbo timer? are these prices shipped?
sukimoto is offline   Reply With Quote
Old 10-16-2007, 08:49 AM   #3
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
pictures of ANY of that?
Neejay is offline   Reply With Quote
Old 10-16-2007, 09:04 AM   #4
slohybrid
slohybrid's Avatar
I have the turbo timer and no shipping would be extra, although I get a very good rate from work.
I do not have pics other than those on my car. The stuff is practically brand new so I didn't feel it is necessary to take pics.
Skydiver
Old 10-16-2007, 10:08 PM   #5
driftedfc3s
driftedfc3s is a name known to alldriftedfc3s is a name known to alldriftedfc3s is a name known to alldriftedfc3s is a name known to alldriftedfc3s is a name known to alldriftedfc3s is a name known to alldriftedfc3s is a name known to alldriftedfc3s is a name known to alldriftedfc3s is a name known to alldriftedfc3s is a name known to alldriftedfc3s is a name known to all
The Peak tie-rods, they come with spacers?
driftedfc3s is offline   Reply With Quote
Old 10-17-2007, 05:40 AM   #6
slohybrid
slohybrid's Avatar
Yes they do.
Skydiver
Old 10-17-2007, 09:57 PM   #7
sukimoto
how much shipped for it?>
Old 10-17-2007, 09:59 PM   #8
Tearlessj
Tearlessj's Avatar
ARC bov come with flange?
Nagasaki Motors
Tearlessj is offline   Reply With Quote
Old 10-17-2007, 10:11 PM   #9
AznDrftr.
AznDrftr.'s Avatar
AznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond repute
Send a message via AIM to AznDrftr. Send a message via MSN to AznDrftr. Send a message via Yahoo to AznDrftr.
Pics pics pics please.
AznDrftr. is offline   Reply With Quote
Old 10-18-2007, 05:36 AM   #10
slohybrid
slohybrid's Avatar
sukimoto price plus 5.00 shippig
Skydiver
Old 10-18-2007, 05:37 AM   #11
slohybrid
slohybrid's Avatar
tearlessj, it comes with a aluminum ARC tube with flange on it.
Skydiver
Old 10-18-2007, 06:44 AM   #12
Titan Uranus
Titan Uranus is an unknown quantity at this point
turbo is very very tempting
Titan Uranus is offline   Reply With Quote
Old 10-18-2007, 06:53 AM   #13
slohybrid
slohybrid's Avatar
buy it. you can have it for that price shipped
Skydiver
Old 10-18-2007, 07:57 PM   #14
slohybrid
slohybrid's Avatar
I would like to send pics but due to the fact there is too much i will only send to serious inquiries on specific parts. Everything is practically brand new. If you need proof that it is real look on my cardomain for some pics.
Skydiver
Old 10-18-2007, 09:01 PM   #15
S14DB
AFC #1
S14DB's Avatar
http://www.zilvia.net/f/showthread.php?t=109058
Old 10-18-2007, 09:03 PM   #16
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
How much would it be to ship the non built sr, to 96816? Also, how much to ship that hood, to the same zip? It's for flip up headlights, right?
speedgod^s13 is offline   Reply With Quote
Old 10-18-2007, 09:58 PM   #17
ripnbst
ripnbst's Avatar
ripnbst is making a name for him/her selfripnbst is making a name for him/her selfripnbst is making a name for him/her self
Do you have any body pieces? Like the front corner lights? I need the assmblies and cover lenses. Just cut the wires inside the fender and sell em to me. I think 20$ US is reasonable.
In the market for a Clean Coupe
ripnbst is offline   Reply With Quote
Old 10-18-2007, 10:02 PM   #18
qt_240
qt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really nice
Im interested in the ChargeSpeed Hood, but i would like to see picture of it first to determine the condition of it, For a faster response please email me at [email protected]. Could you also give me a quote for it Shipped to 60126, IL
qt_240 is offline   Reply With Quote
Old 10-18-2007, 10:12 PM   #19
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
is the arc bov like this if so i want.
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 10-20-2007, 07:31 AM   #20
slohybrid
slohybrid's Avatar
yes to ARC BOV.
I Will send you pics of the hood.
S14DB thanks for sending links on hosting
Guy from hawaii I have to call freight companies to see who is willing to ship there. I do not want to make a bunch of calls only for you to not buy. Do you know roughly how expensive it is to ship there. If so and you are good with that then I will proceed but please do not have me go on a wild goose chase for nothing. If you know freight companies that deliver please list them and I will call, thank you.
hood is for the flip up lights
I do have corner lights the ones in the fender right.
Skydiver
Old 10-20-2007, 11:16 AM   #21
S14DB
AFC #1
S14DB's Avatar
Originally Posted by slohybrid View Post
yes to ARC BOV.
Yeah, that means post pics or thread disappears.
Old 10-21-2007, 09:08 AM   #22
driftedfc3s
Will you do $100 shipped for the tie-rods? If so I will Paypal today.
Old 10-21-2007, 08:30 PM   #23
xHASTEx
xHASTEx has made poor choicesxHASTEx has made poor choicesxHASTEx has made poor choicesxHASTEx has made poor choicesxHASTEx has made poor choicesxHASTEx has made poor choicesxHASTEx has made poor choices
can u pm me pics of the coilovers? and would u mind selling the fenders if there in good condition? thanks
xHASTEx is offline   Reply With Quote
Old 10-22-2007, 09:04 PM   #24
slohybrid
slohybrid's Avatar
Skydiver
Old 10-26-2007, 04:53 PM   #25
cc4usmc
cc4usmc's Avatar
If you still have them im interested in the Battle Version tension rods,Battle Version rear upper control arms,Peak Performance inner pro/ and outer street tie rods w/ boots,Tanabe front under brace. Please send pics (they dont show on my computer) and price quote shipped to 95758. My email is craythornca_at_rushmore_dot_usmc_dot_mil. thanks
cc4usmc is offline   Reply With Quote
Old 10-26-2007, 07:21 PM   #26
mxsx25
mxsx25's Avatar
mxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-known
Send a message via AIM to mxsx25
hey do you have an sr compatible guage cluster? i need one asap due to the jdm one i bought refusing to work lol
mxsx25 is offline   Reply With Quote
Old 10-26-2007, 11:05 PM   #27
kikit-sideways
kikit-sideways's Avatar
kikit-sideways has a little shameless behavior in the past
s13
you sure do have a nice line up, would you happen to still have the radiator, very interested, do you also happen to have the power steering lines for the sr, if so what would be the asking price for those,
kikit-sideways is offline   Reply With Quote
Old 10-27-2007, 11:32 AM   #28
slohybrid
slohybrid's Avatar
My gauge cluster works just fine. and it has the jdm tach.
radiator is available. I also have the power steering lines. dont know price on that yet.
Skydiver
Old 10-28-2007, 01:12 PM   #29
slohybrid
slohybrid's Avatar
updated for sale list
Skydiver
Old 10-28-2007, 03:30 PM   #30
Devil Man
Devil Man is an unknown quantity at this point
is your drive shaft for an abs car? thanks
Devil Man is offline   Reply With Quote
