Old 10-16-2007, 04:39 PM   #1
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Altima rotors with Q45 calipers
Can I use altima rotors with q45 calipers? I'm having a hard time finding a place that will re-drill rotors. I've had these q45 calipers for a while now, and since they bolt right up and I'll need new rotors and pads anyway, why not?
q45 282mm x 28mm vs. altima 280mm x 22mm
Would performance be greatly sacrificed by using this combo? Is it safe?
Someone on another board said "the smaller 2mm dia isnt a big deal and 6mm width difference is easily absorbed throu the pad/pistons"
Neejay is offline   Reply With Quote
Old 10-16-2007, 06:47 PM   #2
cotbu
cotbu's Avatar
I was actually thinking the same thing, but just adding a couple shims.
Of course this would be considered _____________! [script]fill in the blank script[/script]
Old 10-16-2007, 07:05 PM   #3
Vernal
Vernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymore
Send a message via AIM to Vernal
Really would like to know also. Is there any 4 lug rotors that would work with q45 calipers
Vernal is offline   Reply With Quote
Old 10-16-2007, 07:07 PM   #4
ej2civic
ej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the rough
you can use 93-99 altima rotors, with 89-99 maxima calipers, brackets, mounting hardware and pads, the pads will stick off of the rotor by like 1/4 in but it wont hurt your braking or even make any difference
ej2civic is offline   Reply With Quote
Old 10-16-2007, 07:08 PM   #5
Neejay
Neejay's Avatar
Well someone sent me a IM and said they have been using this setup for 2 years and also autox. He said the only thing he had to do was adjust the brake booster/BMC rod. He adjusted it out just a hair and hasn't had any problems. This is on a s13 non-abs with stock BMC.
Old 10-16-2007, 07:09 PM   #6
Neejay
Neejay's Avatar
Yeah, the 180sx setup, but I'd prefer to just use what I have already.
Old 10-16-2007, 07:10 PM   #7
Vernal
how do you adjust the rod? So there are no 4 lug rotors that will work without any adjustment? Is the BMC rod like adjusting the clutch? Anyway, what year altima rotors are the specs you stated?
Old 10-16-2007, 07:20 PM   #8
slim
slim's Avatar
slim is an unknown quantity at this point
heavy throttle sells z32 26mm rotors that are redrilled for 4 lug and powder coated for about 150. i installed mine a couple of weeks ago and they work and look great. the pad fits perfect, it doesnt hang over the edge and is within a few mm of the inside. my brakes worked without any adjustments to the bmc, solid pedal and no lock up under hard braking.
slim is offline   Reply With Quote
Old 10-16-2007, 07:25 PM   #9
Neejay
Neejay's Avatar
With q45 calipers?
Old 10-16-2007, 07:34 PM   #10
slim
slim's Avatar
yeah if you want i can email you some pics i took with my camera phone when i was doing a test fit. the pics dont show the edges but belive me they work.
Old 10-16-2007, 08:28 PM   #11
Neejay
Neejay's Avatar
Yeah, do that for me if you can. neejae (at) gmail.com
I guess the z32 redrilled rotors would be a better match, heat wise.
Old 01-08-2008, 02:28 PM   #12
Neejay
Neejay's Avatar
Bump to see if anyone else has any experience, opinions about this.
EDIT: Nevermind, searched and found a thread that said they're too thin.
Old 01-08-2008, 05:14 PM   #13
Doluck
Doluck is on the path to ruinDoluck is on the path to ruinDoluck is on the path to ruin
Yes... its works fine.
Doluck is offline   Reply With Quote
Old 01-08-2008, 05:17 PM   #14
smelly240
smelly240's Avatar
if you call heavy throttle - they might be able to get you the proper rotors for the q brakes... or see ur local machine shop, or buy a drill bit.
brembo blanks 75$... drill bit 10$... porterfield q45 pads - 80$...
its not hard.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 01-09-2008, 12:04 PM   #15
madd ocx
madd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymore
you can go to fastbrakes.com and they have 4 lug rotors to work with q45 calipers. they have a few brake options. they even sell the whole q45 conversion.
madd ocx is offline   Reply With Quote
Old 01-09-2008, 12:17 PM   #16
TipStylez
TipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enough
Sorry to thread jack, but is there any place out there that sells brackets so i can still use the q45 calipers, but run a even larger rotor?
TipStylez is offline   Reply With Quote
Old 01-09-2008, 12:23 PM   #17
Neejay
Neejay's Avatar
Eh, for $150? I'll just drill some OE blank 5-luggers myself/use a drill press.
Old 01-09-2008, 12:24 PM   #18
Neejay
Neejay's Avatar
Not that I have personally seen/come across.
Old 01-09-2008, 02:52 PM   #19
projectRDM
projectRDM's Avatar
Nick, I can drill your rotors. You can nab that overflow bottle too. Hit me up.
FORMERLY R240NA
Old 01-09-2008, 04:41 PM   #20
Neejay
Neejay's Avatar
Hey man. I haven't gotten them yet, but I was actually going to call you within the next few days to ask you to use your drill press. lol I'll give you a call closer to when I get them/about to get them.
I got a overflow already too. Thanks man!
