Old 09-16-2002, 10:46 PM   #1
WhiteNissanS13
WhiteNissanS13 is an unknown quantity at this point
Send a message via AIM to WhiteNissanS13 Send a message via Yahoo to WhiteNissanS13
my 240sx(dohc) has 155k miles on it. when im driving it around, when i press in the clutch the engine drops down to about 450rpm,and all the lights dim. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/huh.gif" border="0" valign="absmiddle" alt=':huh:'> sometimes it drops down to 450rpm and dies. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cry.gif" border="0" valign="absmiddle" alt=''> Does anyone else have this problem?
also, i have a major grease problem on the door latches(the hook that the door latches onto), i always find the grease to end up on the side of my pants. does anyone know a good remedy to remove all or some of the grease?
WhiteNissanS13 is offline   Reply With Quote
Old 09-16-2002, 11:28 PM   #2
PabloHoney
PabloHoney is an unknown quantity at this point
Send a message via ICQ to PabloHoney
In order to remedy the grease problem, wipe it off =) &nbsp;Easy as that.
The idle problem is pretty easy to fix. &nbsp;If your idle is low all the time, you can just adjust your idle speeed adjusting screw. &nbsp;It's under the intake manifold (under meaning towards the bottom of the engine from the intake manifold). &nbsp;It's a round adjustment screw. &nbsp;If you are looking from the right side of your car at the right side of your engine, look below the intake manifold, and behind the oil filter a little ways. &nbsp;You should idle around 650 plus or minus 50 rpm (although I prefer 750).
'95 240sx
5 spd
LSD
Front STB
Clutchmasters Stage I
5-lug swap
Z32 brakes
Z32 wheels
225/50 Yokohama AVS ES100
Whiteline Adjustable Rear Anti-sway bar
PabloHoney is offline   Reply With Quote
Old 09-16-2002, 11:52 PM   #3
Thurazor
Thurazor's Avatar
Thurazor is an unknown quantity at this point
Send a message via AIM to Thurazor
What does your car idle at when it's just sitting in neutral?
- Jared Edwards
3S Hybrid
[img]too.big.jpg[/img]
&quot;Mandies, sandies, peppermint candies, we do it right and we drink a lot of antifreeze.&quot; - Group X
Thurazor is offline   Reply With Quote
