Old 10-20-2007, 10:01 PM   #1
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
need help. everyone stumped! injectors not priming?
so my problem is that during initial startup the injectors dont prime to start... but if i turn ignition to the on position and take a test light and ground each injector its starts up fine and stays runnin with no problems. i thought it might be an ecu prob but i swapped ecu's and it still does not work. i check all visible grounds and everything looks like it is hooked up correctly. i am using r/c engineering injectors which was stated when i purchased that they were high inpedence so i dont need resisters but if i was told incorrectly what would happen if the injectors were low inpedence.. thanx oh yeah this is a ka
sil80forme is offline   Reply With Quote
