Old 10-24-2007, 11:04 PM   #1
xpl2007
xpl2007's Avatar
xpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfection
How to get my 650ccs to work as 550ccs via fuel pressure?
I know stock sr20det fuel pressure is 43.5 with vacume off. How would i make my 650cc work like 550cc?
Lower fuel pressure? If so how and what formula?
Tweak SAFC II? Dont want to tune with SAFC II just yet, would like to start at fuel pressure..
thanks
http://zilvia.net/f/traderratings.html?u=57636
If i sold you something or gave you it for free post here! Thanks!
xpl2007 is offline   Reply With Quote
Old 10-24-2007, 11:06 PM   #2
DOOK
DOOK's Avatar
buy the correct injectors
<------ Grumpy Old Asshole
DOOK is offline   Reply With Quote
Old 10-24-2007, 11:28 PM   #3
B Love
B Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really nice
It doesnt matter you are jeff. jeff doesnt use 550cc injectors only 650 and above because he is jeff
B Love is offline   Reply With Quote
Old 10-24-2007, 11:51 PM   #4
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
it's 36.8 psi if you want to go that route, but at lower pressures you might start to have problems with atomization and spray pattern. use what ever you're using to tune for 550cc injectors and change it to 650. or just take ltd's advice.
cdlong is offline   Reply With Quote
Old 10-25-2007, 12:08 AM   #5
xpl2007
xpl2007's Avatar
Thanks!
Thanks B Love... lol
With 550 there is little to no tune I have 650cc .. Mines ECU Stage 3 takes care of it..
How did you figure out 36.8?
Just looked at my paper work from the 650cc injectors and they are flowing at: 652,635,635,652..
It says 43.5 psi would be 643cc
40 psi 617cc
35 psi 577cc
30 psi 534cc
Ill do 40 or little less maybe... Then SAFC II Tune for now thanks. Always safe on 100 octane!
Old 10-25-2007, 01:30 AM   #6
NiSmOKnIghTsRBS14
NiSmOKnIghTsRBS14's Avatar
NiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfection
Send a message via AIM to NiSmOKnIghTsRBS14
sell the 650s and buy 550. good luck
NiSmOKnIghTsRBS14 is offline   Reply With Quote
Old 10-25-2007, 11:52 AM   #7
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
Pressure does not equal volume and like cdlong said you will has atomization and spray problems
s13coupedrfter is offline   Reply With Quote
Old 10-25-2007, 01:28 PM   #8
xpl2007
xpl2007's Avatar
I got the print out and it says it safe to do so??? Ill call them.
Old 10-25-2007, 01:43 PM   #9
xpl2007
xpl2007's Avatar
Nismo 550 injectors run at 615 so im good at 40psi it dosnt affect the spray as much any lower will idles and runs fine. Just called and talked with DeatschWerks...
