Old 10-24-2007, 11:34 PM   #1
nicku
nicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enough
turbo upgrade
it might be a repost...but what do i need to do to upgrade the s13 t25 to either s14 t28 or s15 t28?
nicku is offline   Reply With Quote
Old 10-24-2007, 11:55 PM   #2
kevtrinh
kevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond repute
The turbo...you can get away without upgrading injectors and no tune but u shouldn't. search because there is more info floating around this site
kevtrinh is offline   Reply With Quote
Old 10-24-2007, 11:55 PM   #3
panama DRIFT
panama DRIFT's Avatar
panama DRIFT is an unknown quantity at this point
Send a message via AIM to panama DRIFT
first you need to search
try s13 turbo upgrade, it gave me 8 pages of results
G/L
panama DRIFT is offline   Reply With Quote
Old 10-25-2007, 12:01 AM   #4
mizono
mizono is making a name for him/her selfmizono is making a name for him/her selfmizono is making a name for him/her self
the s14~s15 turbo install on an redtop/blacktop s13 motor is pretty simple. The main parts you'll need are as follows
-s14/s15 turbo adapter plates (these are not 100% necessary just make the install so much easier and smoother)
-steel braided coolant and oil lines (if you don't want to waste time bending stock lines)
-turbo nut locking plates (should replace the old ones so the nuts don't shake loose)
-misc. nuts bolts and washers
-exhaust manifold gasket (s15 is reusable)
-.035 oil restrictor (so you don't blow your internal turbo oil gaskets, unless your turbo has one already installed in it).
-turbo gaskets
mizono is offline   Reply With Quote
