Old 10-25-2007, 07:37 PM   #1
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
Prepping 4 drag strip, batt. relocated in the trunk requires kill switch, help/tips?
Last time I couldn't pass tech inspections at the drag strip cause of my battery relocated in the trunk blah blah blah, he mentioned, I needed a kill switch mounted on the outside if you're battery is relocated in the trunk..didn't really go into detail though
Does it need to be a certain type of switch, like a flip type, one you pull out or what? and if anyone has a pic of how they mounted their switch i'd like to get an idea how i should do mine
Indolent is offline   Reply With Quote
Old 10-25-2007, 09:50 PM   #2
TheTimanator
TheTimanator's Avatar
http://store.summitracing.com/partde...5&autoview=sku
there are many others that will work as well, but that one is waterproof.
Old 10-26-2007, 08:51 AM   #3
Suk02Si
Suk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfection
Same type I used to run. It needs to be easily accessable in case you smash your car and they need to kill the batt. I had it mounted on my rear garnish.
Suk02Si is offline   Reply With Quote
Old 10-26-2007, 08:54 AM   #4
mayco_86
mayco_86's Avatar
mayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfection
Same thing happened to my friend when he went through inspection. Summit Racing has a lot of good stuff you will be able to find the kill switch there.
mayco_86 is offline   Reply With Quote
