Old 10-28-2007, 07:57 AM   #1
shinrekka
shinrekka's Avatar
shinrekka is an unknown quantity at this point
highest compression with R4 cam (SOHC)
Even though i havnt owned a 240 in a long ass time, and its gonna be awile till i pay off my new car I still dream of different builds i'd like to do in the future. For my next build i'd like to go all motor SOHC. I know blah blah blah i dont care what you have to say if you think its a bad idea, no i dont want turbo, been there done that.
Alright heres my question, what is the highest compression i can go using a nismo R4 cam. I'd like to run 10:1 but im not sure what the limit is before the pistons hit the valves.
Heres the potential set up
Nismo R4 cam ( possible port + polished head)
rebuilt bottom end, 10:1 compression pistons (maybe overbore?)
obx header, test pipe, 3" apexi N1 (yeh i know its gonna be stupid loud)
custum intake with K+N filter
Fidanza flywheel, UR crank pulley
JWT ecu
Should be good for 170hp I would think?
shinrekka is offline   Reply With Quote
Old 11-07-2007, 06:57 AM   #2
shinrekka
shinrekka's Avatar
No one knows? No one has an R4 cam or done high comp in a SOHC?
Old 11-07-2007, 08:30 AM   #3
aa87
aa87's Avatar
aa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant future
Send a message via AIM to aa87
My friends done it but only made 128.4 to the wheels. We laugh at him because he could have spent that money on an sr with all he put into the ka. This is without a tune or anything but meh.
Hookers and blow.
aa87 is offline   Reply With Quote
Old 11-07-2007, 03:20 PM   #4
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
custom intake manifold would help. also, if you can fab, or have connections, some sort of a equal lenght header can help. go .40 over you wont have issue with it, built head for higher RPMS. The main way to gain HP is more CI, more RPMs, More air.
My friend had some crazy ass header on his d16, it gained 16.5whp over a ebay header. same dyno same day.
KA-T_240 is offline   Reply With Quote
Old 11-07-2007, 03:58 PM   #5
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
you should plan on doing a lot of work to the head, airflow is the weakest link on the KA motor
WheelsDirty
Old 11-07-2007, 04:21 PM   #6
gripstr
gripstr is close to perfectiongripstr is close to perfectiongripstr is close to perfectiongripstr is close to perfectiongripstr is close to perfectiongripstr is close to perfectiongripstr is close to perfectiongripstr is close to perfectiongripstr is close to perfectiongripstr is close to perfectiongripstr is close to perfection
you'll top out at 150 with that setup imo
turbo that biastch!! single cam boosted is
and oh i forget to add, it will probably cost you the same amount.
gripstr is offline   Reply With Quote
Old 11-07-2007, 04:31 PM   #7
shinrekka
shinrekka's Avatar
-I couldnt care less if you laugh at your friend or not, i wasnt asking your opinion. And Im not going turbo again and if I was I wouldnt want an sr, much rather turbo the SOHC.
-The head of course will be port and polished if budget allows. I wont be doing any valvetrain work other then what I need to for the cam.
-As far as tuning is concerned, I have heard jim wolfe tunes conservitivly so i dont think I will be going that route, maybe at first but I just may go with carbs and have them professionaly tuned.
-Im going to document and dyno everything I do with the car. So everyone will know what each modification makes to clear up all the false information out there. I dont plan on breaking 200hp to the wheels but im going to try to get damn near close to the crank.
-Also mach5camaross, I do have a couple connections and can get many things custom fabbed but that may be far down the line. As of now im going to go with whats on the market and what is affordable for those that want to have fun on a budget. Most people cant or dont know were to get custom intake manifolds or headers made. Kooks custom headers is right around the block from me, but most likely i will be going with OBX, i have had good luck with there header on other cars.
Old 11-07-2007, 04:43 PM   #8
decco
decco is on a distinguished road
Send a message via AIM to decco
If you can get some custom fab work done, you should make a ram air intake on your bonnet, like how the Ferrari's and some other cars do it. So when you're up to speed, it allows the air to get forced into the intake, acting like light boost.
Off the top of my head the Ferrari Barchetta is one that does ram air.
decco is offline   Reply With Quote
Old 11-07-2007, 04:52 PM   #9
stinky_180
stinky_180's Avatar
Trader Rating: (26)
you should consider solid lifter conversion from hybridka, they're on special order however. valve float can be pretty bad at constant high RPMs
you can tune the sohc yourself for a lot less than what jwt charges. hybridka.com ECCS-TEC FTW!!!!!
WheelsDirty
Old 11-07-2007, 05:01 PM   #10
Mrpickles15
Mrpickles15's Avatar
Mrpickles15 is a well-known jackass
Send a message via AIM to Mrpickles15
Here's an idea from our good friends at Wikipedia.
http://en.wikibooks.org/wiki/Nissan_...A24E/ITB's
Happy little write up on a few hundred bucks worth of crazy NA power for the KA24E/DE. As a disclaimer, I just googled this, I didn't write it.
White 89 240 coupe and Pearl White 96 SC300.
Sig coming soon.
Mrpickles15 is offline   Reply With Quote
Old 11-07-2007, 05:41 PM   #11
johngriff
johngriff's Avatar
Horrible write up.
Baller write up located here:
http://forums2.freshalloy.com/showthread.php?t=175979
[email protected]
Old 11-08-2007, 09:47 AM   #12
shinrekka
shinrekka's Avatar
Hey, do you guys think i should do this in a stanza, 240, or pickup? I have the option for all 3 right now.
