Old 10-30-2007, 03:33 AM   #1
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
s14 a cupple s14 swap questions.
so im hopefully going to get a s14 for 800 bucks because the owner blew the auto tranny up and the motor runs like complete ass. the only problem is that its an auto. i have a full redtop swap for a s13 and my wrecked s13 sitting at my house. what i was wondering is:
do i need a new whiring harness? and do i need anything thats not on my s13 right now? like clutch master, pedals, tranny sensors. stuff like that?
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 10-30-2007, 04:08 AM   #2
HellonFire
HellonFire's Avatar
HellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud of
Send a message via AIM to HellonFire
You will need to convert the S13 SR Harness to work with the S14. But besides that, its a direct swap.
Tyler
HellonFire is offline   Reply With Quote
Old 10-30-2007, 07:59 AM   #3
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
^^ yep, the power plugs that are on the S13 near the battery are not in the S14. They are located in the "power plug" which is a decent sized connector right near the ECU, it actually makes for much cleaner wiring. Also the wipers will need to be wired up directly to that plug as well, since the s13 wipers are run off a different harness, and the s14 wipers are run off the EFI harness that your pulling out.
http://static.carvolution.org/files/...ionIntoS14.pdf
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 11-06-2007, 07:51 PM   #4
JDMClifford
does anyone know where i can find a diy guide on this, i cant figure out what your talking about, are you talking about the red plug on the s13 that goes on the battery? and do i need to wire it up to the small plug coming off the ecu? and do i need to get a new plug for the s14 interior harness that goes to harness neer the ecu? i am little confused. and how do i wire up the wipers. this sucks a want a nother s13
Parking lot pimping
Old 11-06-2007, 07:54 PM   #5
eastcoastS14
eastcoastS14's Avatar
"cupple"......lolz
eastcoastS14 is offline   Reply With Quote
Old 11-06-2007, 08:18 PM   #6
statik
statik's Avatar
I posted an s13->s14 wiring how to in my last post, but it sounds like you have no clue as to whats going on, i suggest you send your harness out.
Old 11-06-2007, 08:18 PM   #7
JDMClifford
hay so i cant spell. blame it on the weed.
Parking lot pimping
Old 11-06-2007, 08:25 PM   #8
JDMClifford
i can do it my self i jsut need to know what goes where. i guess i should probably start talking it apart then asking questions when i swap the motor. i would just like to do it all in the same day. it should only take a day to pull the motor out and swap the sr in. the only hard part i can see would be the brake pedal, if i dont end up just cuting it. and the what goes where on the interior harness. i know the s13 interiorharness like the back of my hand. but not the s14 one.
Parking lot pimping
