Old 10-30-2007, 09:20 PM   #1
Goldeneye9mm
Goldeneye9mm's Avatar
Goldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura about
Send a message via AIM to Goldeneye9mm
SR is my turbo about to die?
i have a s14 sr20det and it's making a weird noise and i'm 80% sure it's coming from the turbo. it chatters under light boost like 2-5psi at lower speeds.it's not in the rods or valves i've checked. it boosts up fine drives fine no extra lag. and under harder driving (full throttle @ 13psi) the noise pretty much goes away. it's my new toy so i've been beating on it but i don't think i was doing any serious damage. i usually let it cool down for a few minutes after hard driving. so what do you think. btw it's my first turbo car so i really don't know.
Goldeneye9mm is offline   Reply With Quote
Old 10-30-2007, 09:52 PM   #2
cotbu
cotbu's Avatar
compressor surge?
Compressor surge: You can think or surge as the point at which the compressor blades begin to “slip” in the air, losing their pumping ability, much like an aircraft wing loses its lift when it stalls. In a turbo, this happens in a series of bursts, as the blades slip, then bite, slip then bite. This sets up a pulsing wave in the turbo piping and explains why the sound has that characteristic “flutter”.
The interesting thing about compressor surge is that it occurs much more readily at low turbo shaft speeds. At these low shaft speeds, on road cars this is generally between 2000 and 3000 RPM, compressor surge is not much of a problem, as the loads generated by the surge are miniscule compared to what the turbo encounters at high boost. However, if surge occurs at high RPM and boost, it is possible to reduce the turbo life and/or damage the compressor
http://www.gofastbits.com/index.php?...tion=tech_info
Old 10-30-2007, 09:53 PM   #3
Nismoknightska-t
Location: Azusa, socal baby! why do i live this way?? it must be the money!
Nismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfection
Send a message via AIM to Nismoknightska-t
any smoke coming from your exhaust?
NismoKnights
Terrorizing Honda crews since 2003
ls2 powered kouki..all show and GO! putting it down on the streets and the track! LMAO V8
Nismokights on http://www.youtube.com/user/NismoKnights
Nismoknightska-t is offline   Reply With Quote
Old 10-30-2007, 10:07 PM   #4
95gstnj
95gstnj is an unknown quantity at this point
if it was your turbo, most likely the noise would be highest when you are in boost, and you'd probably have alot of smoke when you are in boost
95gstnj is offline   Reply With Quote
Old 10-30-2007, 11:07 PM   #5
driftn_silvia
driftn_silvia's Avatar
driftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to all
if its a whistle in sound you might have a vacuum leak some where... but if its like a scrapping sound everytime you hit boost. you might have shaft play. so ur fins on the turbine are hitting the wall. check your turbo to see if you have shaft play by wiggling the fins.
driftn_silvia is offline   Reply With Quote
Old 10-31-2007, 12:24 AM   #6
NiSmOKnIghTsRBS14
NiSmOKnIghTsRBS14's Avatar
NiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfectionNiSmOKnIghTsRBS14 is close to perfection
Send a message via AIM to NiSmOKnIghTsRBS14
turbo is way gone time for a UPGRADE
NiSmOKnIghTsRBS14 is offline   Reply With Quote
Old 10-31-2007, 12:33 AM   #7
GSXRJJordan
GSXRJJordan's Avatar
Doesn't sound like the turbo, because at full throttle/boost the problem should not go away - maybe your exhaust is loud enough you're just not hearing it? Could be some other vibration also.
Checking for shaft play will tell you. Any amount is bad, but if you can actually see the shaft/blades move when you stick your fingers around in there, it's time for a new one.
Old 10-31-2007, 01:30 AM   #8
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
This only happens while you are boosting right??
Not when you take your foot off the gas correct?(surge)
I had the same thing, before, it was the turbo elbow gasket!
make sure there is no blown gaskets around that area, from
turbo/turbo elbow, or from turbo elbow to downpipe!
i had my turb/turbo elbow gasket replaced and the fluttering stopped.
goodluck.
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 10-31-2007, 10:12 AM   #9
Goldeneye9mm
the gasket sounds like the most likley culprate. it's not surge. i' gonna go out and check for play in a few. but it alomst sounded like it was coming from under the dash like the area right infront of me. thats why i suspected the turbo. i have a new outlet dump pipe so it shouldn't be that. i'll post again after i check the shaft for play. also you can hear the turbo wind down after you shut the car off. it's not loud at all but you can hear it. is that normal?
Old 10-31-2007, 10:28 AM   #10
JDMwannaBE
JDMwannaBE's Avatar
JDMwannaBE is on a distinguished road
thats perfectly normal for a ball bearing turbo. thats the glory of them, they spin so easily that when you shut the engine down they still spin freely. mine does the same thing, if you go back to the muffler you'll hear it real well....lol.
JDMwannaBE is offline   Reply With Quote
Old 10-31-2007, 11:12 AM   #11
civilized_drifter
civilized_drifter's Avatar
civilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of light
Send a message via AIM to civilized_drifter
have you checked for shaft play?
civilized_drifter is offline   Reply With Quote
Old 10-31-2007, 11:27 AM   #12
Goldeneye9mm
just checked "my shaft" from the intake side. it feels like ther is more play on the exhaust side. it moves in like a pendalum motion from the nut. like the intake side is tight but the exhaust side moves. ether way there is some play. how hard are they to rebuild? and or who does it? and where could i get the parts to do so? or do any of you have a spair i could buy? lemme know.
Old 10-31-2007, 12:37 PM   #13
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
there are t25 rebuild kits available in alot ofplaces DSMs had the same t25. you can search for "garrett t25 rebuild kit" or anything like that and i know for a fact egay has them. if you can use basic tools and read a blow-up diagram, you can rebuild it yourself.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 10-31-2007, 12:51 PM   #14
GabeS14
GabeS14's Avatar
or you could take it to a professional shop to get a PRO opinion, before you spend hundres of dolars.
a gasket could only cost you $30 bucks, if it was that instead!
Old 10-31-2007, 11:56 AM   #15
JDMwannaBE
JDMwannaBE's Avatar
you'd be better off to replace it. by the time you spend the cash to rebuild you'd spend about the same. but i wouldnt run high boost on it until you can fix it.
Old 10-31-2007, 12:08 PM   #16
mayco_86
mayco_86's Avatar
mayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfection
I would just upgrade before that compressor wheel fly's off.
mayco_86 is offline   Reply With Quote
Old 10-31-2007, 01:08 PM   #17
ichibans13.5
ichibans13.5's Avatar
ichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choices
if it sounds like a dentist drill the turbo is going - shaft play as said prior is also an easy way to tell - but that said garrett turbos last at least 80k - so if its the problem either replace it or drive it till u pour out white smoke out of your exhaust
ichibans13.5 is offline   Reply With Quote
Old 10-31-2007, 02:30 PM   #18
Goldeneye9mm
well i can't afford a new one and it's a t28 on a s14 motor. would the t25 kit still work? like i said i'm a newb to the turbo world so over inform me if possible.
Old 10-31-2007, 02:56 PM   #19
civilized_drifter
if you want to rebuild it there is a place in nashville that rebuilds turbos called turbo auto. they do great work.
(615) 383-6242
Old 10-31-2007, 07:21 PM   #20
Goldeneye9mm
http://cgi.ebay.com/ebaymotors/GT28R...spagenameZWDVW
what do you think. i know it's a cheapy but i'm broke. please give honest opinions.
Old 10-31-2007, 07:26 PM   #21
driftn_silvia
heck no...lol. imo i wouldnt buy generic product. i dont trust them. there couple of t28 around in the forum for sale for about the same price. check the F/S section.
Old 10-31-2007, 07:35 PM   #22
trogdor
trogdor has a brilliant futuretrogdor has a brilliant futuretrogdor has a brilliant futuretrogdor has a brilliant futuretrogdor has a brilliant futuretrogdor has a brilliant futuretrogdor has a brilliant futuretrogdor has a brilliant futuretrogdor has a brilliant futuretrogdor has a brilliant futuretrogdor has a brilliant future
i have the same symptoms but at higher rpms too. im pretty sure it's my turbo inlet gasket because i can see that it's blown
trogdor is offline   Reply With Quote
Old 10-31-2007, 07:52 PM   #23
speed_racerx
speed_racerx's Avatar
speed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to allspeed_racerx is a name known to all
Send a message via AIM to speed_racerx
so... high pitch whistle like sound is bad? fu$#in A....
Aircraft mechanics, so pilots can have heroes too
speed_racerx is offline   Reply With Quote
Old 10-31-2007, 07:56 PM   #24
Goldeneye9mm
well i just had the gaskets replaced. and it's a chatter not a whistle. and i definatly have shaft play.
Old 11-01-2007, 12:35 PM   #25
Goldeneye9mm
ok well all the kits i looked at don't include the dual ball bearings. or am i reading them wrong. like this one
http://cgi.ebay.com/ebaymotors/COMPL...spagenameZWDVW
any more infor would help. i am a mechanic so i assume i could handle this. i just wanna make sure i do it right.
Old 12-18-2007, 04:15 PM   #26
Goldeneye9mm
SR
ok i'm re-opening this thread cause it's still making the noise and it's getting louder. ok it only happens when the car in FULLY warmed up and it sounds like sticking a pen in a plastic box fan only it changes consistant w/ the engine rpms. it WILL NOT make the noise sitting still. hence the fustration cause i cant reproduce it w/ the hood open in my garage or driveway. someone has had to had this problem before. i'm not asking for any miracles i just need to know what i should take apart first. any input is welcome. thanks
Old 12-18-2007, 06:59 PM   #27
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
first of all stop hyperlinking ebay links! & 2nd you can get a sr turbo way cheaper!!
S13Boosts is offline   Reply With Quote
Old 12-18-2007, 08:08 PM   #28
Goldeneye9mm
well i have an s14 sr20 in an s14 so i need a ballbearing turbo. i don't want to down grade to a t25 or a wet bearing t28. but anyway, if you know where to get a t28 bb turbo cheaper than that please sen a lind or some info. thats the cheapest one i'vebeen able to find. thanks
Old 12-18-2007, 04:31 PM   #29
serturbo
serturbo is an unknown quantity at this point
What have you done to remedy the problem so far? Change turbo?
serturbo is offline   Reply With Quote
Old 12-18-2007, 05:31 PM   #30
Goldeneye9mm
well i've checked the shaft for play and it has some but not a huge amount i noticed the other day the my test pipe gasket was leaking but thats not where i'm hearing the sound. i would love to replace the turbo but i'm so strapped right now i can hardly afford to keep food on the table. any gasket or parts donations are greatly appreciated
