Sr20det bogging at 4000rpm...???
I just installed an sr20det blacktop, everything went in smooth, idle is good, no boost leaks, turbo is good...minimal to no shaft play, no leaks, oil is at spec, oem BOV...only upgrade is a walboro 255 , mishmoto and air intake, done during the install.
At 4000rpm in every gear it seems to bog and hold back???? Any one experience this before?...if so solution ? any advice much appreciated.
CAS was adjusted to spec.
FONT="Century Gothic"][/FONT]
