clutch question
i've been having the notorious car wont go in gear bullshit with my car, well i replaced the clutch fork, TOB, pivot ball, all the clips, slave cyl, etc... i adjusted the pedal then took off the clutch dampener and bled the hell out of the clutch last night then again today... the car goes through gears like normal with the car off. today i was curious so i took the boot out and looked at the TOB on the pressure plate and everything seems good... i put a 2x4 between the seat and the clutch pedal to put pressure and the TOB pushes the pressure plate in... i even bled the clutch to see if it was actually pressed in... anyone have any clues of what to check next??? can the pressure plate still be bad? when i took the tranny off it looked good, no broken teeth or anything.
i put the car up on jack stands and the synchros obviously work because i could get it in the gears but the wheels would start spinning before it went in gear...
www.DecalsStore.com custom decals... buy a premie account and save money from me
