Old 11-07-2007, 12:18 AM   #1
bmx22
bmx22 has a spectacular aura aboutbmx22 has a spectacular aura aboutbmx22 has a spectacular aura aboutbmx22 has a spectacular aura aboutbmx22 has a spectacular aura aboutbmx22 has a spectacular aura about
black top with red top ecu
i had my motor for 2 years runs great but iits a black top s13 and i have been running a red to #63 ecu is that bad could it harm any thing i know theres like almost no difference in the motors but why do they come with different ecu # .....any in fo would be great thanks also what # is the black top...thanks
bmx22 is offline   Reply With Quote
Old 11-07-2007, 12:40 AM   #2
AznDrftr.
AznDrftr.'s Avatar
AznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond repute
Send a message via AIM to AznDrftr. Send a message via MSN to AznDrftr. Send a message via Yahoo to AznDrftr.
Redtops come with #62's. I believe blacks come with #63. But i believe that is, correct me if im wrong. thanks.
AznDrftr. is offline   Reply With Quote
Old 11-07-2007, 06:21 AM   #3
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
if it ain't broke don't fix it. i believe the only difference may be the o2 sensor pins. do an ecu pinout comparison.
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 11-07-2007, 06:34 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
E5 and 63 ECUs interchange...Same pinouts, same engine, same harness...
EDIT: OOOOPS meant to type up E5, early blacktops 93-96 ish.
CLICK HERE!!!
Old 11-07-2007, 07:42 AM   #5
180sxLove
180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about
I beleive the Redtop ecu is designed for the smaller O2 sensor, and the blacktop reads the bigger one.
180sxLove is offline   Reply With Quote
Old 11-07-2007, 08:19 AM   #6
Sileighty_85
Sileighty_85's Avatar
Black Top ECU has a few pins moved around
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-07-2007, 09:15 AM   #7
SirWarrior
SirWarrior is an unknown quantity at this point
Redtop MT-62
Redtop AT -63
Blacktop MT- E5
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 11-07-2007, 12:30 PM   #8
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
Originally Posted by fliprayzin240sx View Post
J4 and 63 ECUs interchange...Same pinouts, same engine, same harness...
Are you sure... Im pretty sure that If you did that, You would only get spark to one cylinder.... Due to a different pinout for the coils.
jskateborders is offline   Reply With Quote
Old 11-07-2007, 12:46 PM   #9
liliechen
liliechen is an unknown quantity at this point
Send a message via MSN to liliechen
Couple of pin are @ different location for 62 (S13 redtop) and E5(S13 blacktop). If you read the map of these 2 ecu 62(50f00) and E5(50f05), there is a major difference in fuel map, even the rev limit is different.
liliechen is offline   Reply With Quote
Old 11-07-2007, 08:38 PM   #10
bmx22
ok so every person that posted told me something diferent........any real facts
Old 11-07-2007, 08:53 PM   #11
jskateborders
Your wrong, but nice try...
63 is s13 silvia/180sx auto ecu. I know that for a fact. So, no you will not run into any issues, you are fine. You prolly dont have the speed cut at 118 right? The only s13 ecu that is not compatible without repining is the j4 from the typex because it came with more electronic features that are pinned in there. Anyone back me on this one
Old 11-07-2007, 09:02 PM   #12
bmx22
i do have the speed cut i need to look i might have a #62 but I do have a black top the head has the fins in the front, is the fuel maps the same for the black and red top ecu.
Old 11-07-2007, 09:21 PM   #13
jskateborders
I would assume since they both are factory rated for the same power. If you do have a fuel cut, then I beleive that you probually have the # 62.
E5 62 and 63 all work with the same harness. j4 does not. I learned that one the hard way.
Old 11-07-2007, 09:36 PM   #14
fliprayzin240sx
OOOps my bad, I meant to type E5 ECUs. J4s are the kouki Type-x ecu and they have some pin out difference over the E5/63 ECUs.
But yah E5 and 63 ECUs are interchangeable. The only difference between an early blacktop and redtop S13 engines are the ECU code, o2 sensor size (but you can still interchange those, just use what elbow size your using) and the blacktops have better cooling (head fins).
Im saying this since ive had personal experience on this, Ive run both 63 and E5 ECU and swapped engines around.
CLICK HERE!!!
Old 05-31-2008, 10:40 AM   #15
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
so confusing this thread.
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 05-31-2008, 12:13 PM   #16
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
You'll want to run a skinny o2 if you have a redtop (#62 or #63) ecu.
Old 05-31-2008, 01:07 PM   #17
smelly240
smelly240's Avatar
the one with the pins moved around is the J4/5 not the E5/6 the 62/63 is the same as the E5/6.
The small and big o2 sensors output the same - so its whatever fits ur car.
I've swapped those ecus back and forth and tuned both with daughterboards... You'll have no problems.
Now i dont run either anymore - just use the programmable narrow output off the innovate.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
