Old 11-21-2007, 01:25 AM   #1
SilVertibLe
SilVertibLe's Avatar
SilVertibLe is an unknown quantity at this point
WTB: T25 oil drain fitting, stock sr intake
i need to get a hold of a t25 oil drain fitting, the metal 2 bolt flange pipe that bolts to the bottom of the turbo, then you attach the rubber hose to it which then attaches to the fitting on the oil pan. If possible i need the oil fitting and the propper rubber drain tube.
I also need a stock sr rubber intake tube, the one that connects the maf to the turbo inlet.
SilVertibLe is offline   Reply With Quote
