Old 01-12-2002, 08:06 PM   #1
AZN GTR
AZN GTR is an unknown quantity at this point
Got a 97 240, and I need spark plugs because the car gets a little bit of delay when starting, and it's got about 27000 miles on it, so it needs a tune up.  Just got a new battery too, but I need to change spark plugs, is it easy or not?  Can someone give me detailed instructions?  I could always get it done, it's just that I am a little short on money right now.  Thanks.
AZN GTR is offline   Reply With Quote
Old 01-12-2002, 08:12 PM   #2
mistert
Pearl White Mike
mistert is an unknown quantity at this point
Send a message via ICQ to mistert Send a message via AIM to mistert
its pretty easy, you should only need a ratchet and an extension for spark plugs (you may need an adapter if you have some crazy kind of spark plugs, but i doubt it). you shouldnt really need new plugs at 27k miles unless they fouled early, the factory ones should last alot longer than that.
anyways, go get a haynes service manual for your car, it'll be your best friend when doing basic maintenence and modification on your car
mistert is offline   Reply With Quote
Old 01-12-2002, 08:52 PM   #3
Guest
Posts: n/a
all you need is a 3/8 ratchet and extension with a (dont quote me on this size) 5/16 i beleive someone correct me (or its a 5/8) spark plug socket. take the old ones out pput anti sieze on the new ones and tighten them back up about 3/4 after you have them tight or to get more technically use a torque wrench and see what the spec is.
Old 01-12-2002, 10:26 PM   #4
NoTuchn
NoTuchn is an unknown quantity at this point
if you stick to the haynes manual, itll have pictures and everything. much easier to read from there than have it explained here. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
NoTuchn is offline   Reply With Quote
Old 01-13-2002, 09:05 AM   #5
Guest
Posts: n/a
I work at Pep Boys, they don't have one for 240, just 200sx, and sentra. &nbsp;Where can I find one?
Old 01-13-2002, 02:42 PM   #6
AZN GTR
Ok, first I thought it was the battery, but I got a new energizer one last night, and this morning, it was still having problem starting. &nbsp;But the thing is, it's only when I leave the car there for a long time and I go to start it that I have problems, but let's say i go buy something and come out of the store and try to start it, it's got no problem at all. &nbsp;Is it the spark plugs?? &nbsp;Or wires?? &nbsp;It just keeps cranking for a lot time and sometimes it starts, and sometimes it doesn't.
Old 01-13-2002, 04:26 PM   #7
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
sound slike you've got cold start problems. &nbsp;Is the car running any worse? &nbsp;Are there any other symptoms besides had to crank when cold?
sykikchimp is offline   Reply With Quote
Old 01-13-2002, 05:04 PM   #8
Guest
Posts: n/a
No it dioesn't. &nbsp;Does it sound like something bad is happening to my car??? &nbsp;Could it just be the spark plugs?
Old 01-13-2002, 05:21 PM   #9
geeaj
geeaj is an unknown quantity at this point
Take your battery and have it tested. It could be that the battery itself is dying out. Another long shot could be that your alternator is starting to go and not charging your battery. You can test this as well, if the battery checks out to be okay.
Start your car, turn on all of your power accessories (radio, lights, AC, etc). Pop up the hood and disconnect the battery. If the car dies, then your alternator is shot.
When your car is running, the alternator is supposed to run all of your accessories and recharge your battery.
Hope this helps.
geeaj is offline   Reply With Quote
Old 01-13-2002, 07:31 PM   #10
AZN GTR
Thanks for that suggestion, I think I will try that. &nbsp;I just got a new battery last night, so that can't be it, how much would it cost to get a new alternator?
Does anyone know if spark plugs work better when they are warm? &nbsp;Because I think that's the reason, because I doubt the alternator would be the problem, the car's only got 27k miles on it.
Old 01-13-2002, 07:48 PM   #11
my240likenoother
my240likenoother is an unknown quantity at this point
Send a message via Yahoo to my240likenoother
fuel filter
my240likenoother is offline   Reply With Quote
Old 01-13-2002, 07:56 PM   #12
AZN GTR
If it's the fuel filter that's creating the problem, wouldn't the car always have problems starting? &nbsp;right now, I only have problems starting when I leave the car there for a long time, other times it just starts real quick. &nbsp;Anyone else thinks it might be the fuel filter???
Now I think about it, it can't be the alternator, because that would also mean I would have problems starting all the time, not just in the morning.
