Old 12-06-2007, 03:35 PM   #1
sr20 driver
sr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choicessr20 driver has made poor choices
sr throttlebody
can anyone plz help me out were does the little tube go from the bottom of the throttlebody?
sr20 driver is offline   Reply With Quote
Old 12-06-2007, 03:37 PM   #2
steve shadows
steve shadows's Avatar
IT GOES INTO THE GATES OF HELL
which one are you talking about?
Like Me on FaceBook !
Old 12-06-2007, 03:48 PM   #3
sr20 driver
the little one rite under the big whole
Old 12-06-2007, 03:50 PM   #4
burnsauto
burnsauto's Avatar
take a picture of what you're talking about exactly.
if its the one im thinking of...i have it blocked off on my car. smaller one on top goes to the fuel pressure regulator, bigger one to the bov.
Old 12-06-2007, 04:05 PM   #5
sr20 driver
You are talking about the top ones i need the bottom one.
Old 12-06-2007, 04:11 PM   #6
welddrft
welddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choices
Its suppose to go to the charcoal canister, but you can block it off.
welddrft is offline   Reply With Quote
Old 12-06-2007, 04:13 PM   #7
sr20 driver
whats the charcoal canister? were is it at?
Old 12-06-2007, 04:19 PM   #8
welddrft
Most likely you dont have one and its for emissions to vent fuel vapor from the tank sucking it through the hose under the TB. Its not important and only used for emissions and is not needed at all.
Old 12-06-2007, 04:27 PM   #9
sr20 driver
so i should i just block it or leave it open?
Old 12-06-2007, 04:29 PM   #10
welddrft
Yup, just block it off. It wont hurt anything. Just one less vacuum hose to deal with.
Old 12-06-2007, 04:36 PM   #11
sr20 driver
o what its vac so can i connect like a boost gauge or something to it?
Old 12-06-2007, 04:40 PM   #12
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
BOV maybe????
Old 12-06-2007, 04:41 PM   #13
welddrft
kinda but not really because with the throttle closed you wont get a vacuum reading until the throttle opens a bit. So if you have a boost gauge that doesnt show vacuum then it might be ok. But the vacuum usually used for the boost gauge reading is the small one on the top left of the TB also used by the oem pressure regulator.
Old 12-06-2007, 04:44 PM   #14
sr20 driver
o ok well thanx anyways
Old 12-06-2007, 09:41 PM   #15
nissanguy13
nissanguy13's Avatar
nissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant future
http://www.sillbeer.com/vaccum.php This site will tell you where to put the vac lines. Do not discard the canister if you still have it. It will only help the car, not hurt or restrict it. It isn't going to effect the car either way but why not leave something on that isn't causing a problem or just might do it's job one day. And no there is nothing you can hook up to it if you take off the canister, just cap it.
Originally Posted by unicoladron;
dick, i had like 4 posi reps in a row and you ruined it
nissanguy13 is offline   Reply With Quote
Old 12-06-2007, 11:04 PM   #16
Doluck
Doluck is on the path to ruinDoluck is on the path to ruinDoluck is on the path to ruin
it goes on the FPR. Ya know .... the only other nipple on the whole car that same size!
Doluck is offline   Reply With Quote
