Old 12-08-2007, 10:14 AM   #1
wannabe-silvia
wannabe-silvia is making his/her stupidity well-knownwannabe-silvia is making his/her stupidity well-knownwannabe-silvia is making his/her stupidity well-knownwannabe-silvia is making his/her stupidity well-knownwannabe-silvia is making his/her stupidity well-known
injecotrs not spraying fuel
ok i put a greddy intake manifold on my car and i tryed startted the car for the first in about 5 months yesterday. For some reason my injectors are not spraying fuel.. I called Battle ground and he told me to remove fueal turn car over and fuel should come out...didnt ....i bleive the problem is electrical...there is only a couple wires that were removed and i am positive that they were put back in a necessary fashion....if anyone can help i would greatly appreciate it....if anyone that has dealt with and wants some pics to see if anything was done a proper fashion let me know and i will post pics....thanks
wannabe-silvia is offline   Reply With Quote
Old 12-08-2007, 12:31 PM   #2
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
i had this same problem... is ur car a s14 with a s13 sr swap?
also can you hear the fuel pump come on? if you have a walbro you should be able to hear it from the driver seat.
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 12-08-2007, 12:42 PM   #3
welddrft
welddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choiceswelddrft has made poor choices
Check your fuel pump fuse and make sure you put the injectors clips in the correct orientation. Each wire should be shorter than one another with the longest stretching to the #1 injector.
welddrft is offline   Reply With Quote
Old 12-12-2007, 10:05 PM   #4
wannabe-silvia
weld drift can elaborate on waht u mean there. the fuse is good.... yes i know the fuel pump is pumping... i cranked the car and loosed line to the rail fuel had plenty of pressure.... but what do u mean about these wires...the first thing i was gonna do was the cam senser...no i have 89 s13 with redtop....
Old 12-14-2007, 09:33 PM   #5
wannabe-silvia
anyone (message to short taking up some space)
Old 12-14-2007, 09:53 PM   #6
mothon
mothon's Avatar
mothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond repute
Try a different ecu. Check your grounds.
mothon is offline   Reply With Quote
Old 12-18-2007, 09:16 AM   #7
myzislow
myzislow's Avatar
myzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond reputemyzislow has a reputation beyond repute
is the ecu grounding the injectors?
myzislow is offline   Reply With Quote
