Old 12-12-2007, 09:08 PM   #1
thedecapitator
thedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choices
s13 jdm gauge cluster swap diy
89-90 sohc gauge cluster so if u have sr20det u must do a dohc or jdm gauge cluster
tools needed
1. screwdriver
2. 12mm socket (for the removal of the bolts of steering colum)
3. ratchet^^
1. remove the kick panel under the steering wheel 5 screws
2. remove all the plugs to the popup buttons,emergency lights, etc.
3. remove (2) 12mm bolts on ur steering column ( it allows to have more room to work with)
3. now u can adjust the lever of ur steering wheel to drop it all the way down so u can remove the bezel ( the thingy with all the buttons lol)
4. ur gauge cluster will have 3 screws one on top and (2) to the side
5. slowly pull the gauge cluster toward u and not too hard u dont wanna F* up the plugs on the back of it
5. unplug all the plugs from behind the sohc gauge cluster and plug em into ur jdm gague cluster
6. now screw everything back in in the order it was and ur done!
okay well if this has already been explained feeel free to delete i was just trying to give some info. since when i searched it came up empty...
thedecapitator is offline   Reply With Quote
Old 12-20-2007, 12:53 PM   #2
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
Alrighty, I need to pull my gauge cluster to see if it if the culprit of some of my other issues. Here's the question, I've done this before but can't seem to get it done with out breaking the plastic bezel. Anyone have any pointers on how to get that thing off with out cracking it????
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 12-20-2007, 12:58 PM   #3
Gjohnson7
Nevermind guys, I think I just gound my answer.
Another post I found said to drop the steering column, so I guess that's what I will try.
Old 12-20-2007, 12:59 PM   #4
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
Did you drop the steering column?
two 12mm nuts and two 12mm bolts
lok is offline   Reply With Quote
Old 12-20-2007, 01:03 PM   #5
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Just remove the 2 bolts closest to the steering wheel, remove them completly, but not the ones furthust away, keep them on the threads still, just leave enough slack for you to work with.
duffman1278 is offline   Reply With Quote
Old 12-20-2007, 01:13 PM   #6
thedecapitator
yea what he said man... like i said on the post their just the (2) bolts u have to remove from the steering column and as soon as u do just push the steering wheel down with the lever also and u can easily remove the bezel
