Old 12-14-2007, 08:40 PM   #1
jakethesnake
jakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymorejakethesnake is not welcome here anymore
electrical inside doesnt work...
got my s13 SR running 2day, everything is good but nothing works inside..like the windows wont roll down, radio wont work, tailights, blinkers, did anyone have this problem before?? what did you do??
jakethesnake is offline   Reply With Quote
Old 12-14-2007, 10:15 PM   #2
njd07
njd07's Avatar
njd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfection
Send a message via MSN to njd07
check the fuses and report back to us.
njd07 is offline   Reply With Quote
Old 12-16-2007, 06:43 PM   #3
jakethesnake
yea i checked the fuses and everythign seems good...anyone got any other thoughts
Old 12-17-2007, 11:26 AM   #4
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
Define "yea i checked the fuses..." Did you just open the fuse boxes and say, "yup no smoke they look good" or did you physically pull each one out and check to see if it's blown? Not trying to be a dick but you see all levels here and I don't know you or anything about your skills.
-Retired
98s14inaz is offline   Reply With Quote
Old 12-16-2007, 06:53 PM   #5
Gnnr
Gnnr's Avatar
Get a test light and start tracing everything back from the battery...
Gnnr is offline   Reply With Quote
Old 12-17-2007, 06:41 AM   #6
jakethesnake
i think i might of messed up on wiring the dash clip by the ECU, but im not sure ...im going to check that 2day
Old 12-17-2007, 07:41 AM   #7
GSXRJJordan
GSXRJJordan's Avatar
You'd be hard pressed to mess up the electrical inside by screwing up the ECU dash clip wiring - the dash gets power/all "idiot light" signals through the chassis harness, not the ECU harness.
Check fuses one more time, in the fuse box in the passenger side of the engine compartment and at the drivers side kick panel. After that, you'll want to pull the plugs going out of the inside fuse panel (they'll be snaked around all over the place) until something changes. Also, make sure your ignition is actually giving out juice on the ACC setting.
Old 12-17-2007, 03:52 PM   #8
jakethesnake
i pulled all fuses and everything looks good
Old 12-17-2007, 06:24 PM   #9
g6civcx
g6civcx's Avatar
You need to measure both pins of each fuse with an ohmmeter for continuity. If you're not careful sometimes you can miss a blown fuse just by looking at it.
Old 12-17-2007, 03:56 PM   #10
rlpinoy
rlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choices
check your relays inside of the hood of the car. either that or you have a connection somewhere that came off.
FS Exhaust, Q45 ignitors, & MORE!
rlpinoy is offline   Reply With Quote
Old 12-17-2007, 08:10 PM   #11
GSXRJJordan
^^^ or, just get one of those little "fuse testers" that has prongs and a piezo speaker/light. If you get continuity, you get a buzz/light. Otherwise, replace the sucker.
Old 12-17-2007, 10:07 PM   #12
jakethesnake
thanks everyone!!!
Old 12-18-2007, 12:19 AM   #13
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Check the main battery fuse in the underhood fuse block. Also make sure you wired your alternator charge wire correctly to that fuse.
Old 12-19-2007, 02:44 PM   #14
jakethesnake
allright so i put in a new fuse and it poped right away...its the one in the passanger side fuse box thats in the engine bay.. the fuse is called FL75A ALT
Old 12-19-2007, 04:42 PM   #15
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
'Poped' as in it blew right away? Check your grounds.
Old 12-19-2007, 04:45 PM   #16
jakethesnake
yes i just pluged it up and blew in 1 second
Old 12-19-2007, 07:51 PM   #17
GSXRJJordan
That's your alternator fuse - you've either got a short in your main positive wire to your alternator, or a really horrible ground from your engine to the chassis/battery, or your alternator is blown. The first two are MUCH more likely.
Old 12-19-2007, 09:16 PM   #18
rlpinoy
have you taken off your battery lately? sounds like you may have you cables on backwards!
Old 12-20-2007, 10:37 AM   #19
jakethesnake
i disconected all my wiring going into my alternator and i noticed that i have a thin brown and a thin black wire cut...does anyone know what that goes to??
Old 12-20-2007, 01:24 PM   #20
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Big pic so you can read it better.
Old 12-21-2007, 08:04 PM   #21
jakethesnake
allright i found out what wire pops the fuse, its the thick white wire that goes to the alternator...it looks like a thick ground but im not sure what it is...can anyone help me out ?? ??
Old 12-21-2007, 08:05 PM   #22
jakethesnake
once i plug up the thick white it pops right away
Old 12-21-2007, 11:09 PM   #23
Gnnr
Gnnr's Avatar
According to the wiring diagram above there are 2 white wires (denoted by a W in the diagram) coming out of the Alternator. Both go to the Battery. Then there is a White/Red wire that goes tot he "Engine Room Harness".
Again, make sure that the Black wire (ground) is making good contact to the body chassis (bolt is on tight). Try removing it and cleaning up the contact with a wire brush.
Also you can have your alternator tested, it may be putting out a bad voltage.
Old 12-23-2007, 10:30 PM   #24
jakethesnake
the thick white wire connects to the back of the alternator should have a plastic mounting adapter thing...mine doesnt , it only has the rubber housing that goes over all of it..do you guys think that might cause it all
Old 12-24-2007, 09:16 AM   #25
projectRDM
projectRDM's Avatar
If the plastic insulator underneath it is broken, you're grounding it directly to the case. Remove the wire, replace the fuse. If the fuse does not blow, reconnect it. If it then blows, the insulator is broken off, you'll need to do something to keep the power lead from contacting the alternator case. either make a spacer out of plastic or something non conductive, or replace the alternator entirely.
FORMERLY R240NA
