Old 12-18-2007, 11:55 PM   #1
holiday
holiday is an unknown quantity at this point
ka24de wire harness Question
Im having a ka24de swapped into my s13 by a local tuner shop and they say my previous harness was burnt up and recommend that i get a new. the only problem with this is that they seem be having a hard time finding one. According to them they say there are 3 different engine bay harnesses for the 91-93 s13. My question is are there infact 3 different harnesses and if so are they interchangable? im trying to find one on my own to speed up the process. my car is a 92. thanks for any replys
holiday is offline   Reply With Quote
Old 12-19-2007, 02:05 PM   #2
beetlejuice
beetlejuice's Avatar
beetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura about
The HICAS harness is a bit different due to a couple of extra plugs for the HICAS thing on the lower passenger side frome rail, and the ABS unit.
Other than than, I don't know of any differences, unless the auto and manual harnesses are different.
I'm sure you can use any of the available harnesses, you might end up with extra plugs depending on the harness you get and the chassis you have.
Maybe a wiring guru will chime in to set the record straight.
jollydwarf.com
beetlejuice is offline   Reply With Quote
Old 12-19-2007, 02:25 PM   #3
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
auto and manual harness is about the same my s13 was an auto before i did a 5-speed swap.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 12-19-2007, 03:02 PM   #4
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
I suggest you PM Russ [ProjectRDM nowadays] or start hitting the junkyards.
Old 12-19-2007, 05:49 PM   #5
tunerzimage
tunerzimage's Avatar
tunerzimage has a reputation beyond reputetunerzimage has a reputation beyond reputetunerzimage has a reputation beyond reputetunerzimage has a reputation beyond reputetunerzimage has a reputation beyond reputetunerzimage has a reputation beyond reputetunerzimage has a reputation beyond reputetunerzimage has a reputation beyond reputetunerzimage has a reputation beyond reputetunerzimage has a reputation beyond reputetunerzimage has a reputation beyond repute
Send a message via AIM to tunerzimage
I have a non HICAS harness if you're interested, PM me.
(909) 628-1707 - Chino, CA http://www.tunerzimage.com
tunerzimage is offline   Reply With Quote
