Old 12-23-2007, 01:18 AM   #1
frankist
frankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura about
ka24de front cover removal.
so im replacing my timing chain, and i have the upper cover off, the crank pully off, i took the ac compressor and ps pump out just so i could get more leverage to pry the cover off, but still no luck. the lower cover just wont come off, i took the wood drufff key off, just to see if it was somewhat hindering the cover from being removed, but thats not it, am i just not prying hard enough? it seems to be getting caught at the crank =\
http://www.zilvia.net/f/showthread.php?t=155138
i might try this tomorrow dropping the oilpan just to see if anything being caught.
upon doing further research i believe this might be it, the oil pick up tube, if theres anything else i should know, if someone could chime into to help, ill really apprieciate it. =)
frankist is offline   Reply With Quote
Old 12-23-2007, 02:58 AM   #2
civilized_drifter
civilized_drifter's Avatar
civilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of light
Send a message via AIM to civilized_drifter
its the oil pick up tube that is hindering you from taking it off. it would make life easy if you took the pan off.
is the motor still in the car?
civilized_drifter is offline   Reply With Quote
Old 12-23-2007, 10:36 AM   #3
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
the oil pan needs to come off. The oil pump(located in the lower timing chain cover) has a pickup tube that goes down into the oil pan. You got the chuck out of the crank right? Also remove your water pump.
After the oil pan and pump pickup are off and all the bolts are loose the only thing that should be holding the cover on is the goo that is used to seal it between the block and the timing cover.
KA-T_240 is offline   Reply With Quote
Old 12-24-2007, 01:39 AM   #4
frankist
verified =) the motor's out of the car. oil pan removed and oil pick up tube was the issue to this problem. found the answers on zilvia. thanks again. =)
Old 12-24-2007, 09:10 AM   #5
KA-T_240
Glad we could help. Have fun with you project.
Old 02-03-2008, 09:07 AM   #6
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
the pickup has a 10mm bolt holding it to the girdles, even if you could have agot it off the bottom of the pump/cover, you d have a to take it off to get it back on. alot of people seem to have oil pump questions lately
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 02-03-2008, 10:28 AM   #7
projectRDM
projectRDM's Avatar
Ya, two months ago. Plus, only the S13 KA has the additional bolt.
FORMERLY R240NA
Old 02-03-2008, 07:47 PM   #8
ryan hagen
ryan hagen's Avatar
i did a search and thought i backed out of it to the regular page, oddly enough my search wasnt anything to do with this.
Old 07-27-2010, 04:26 PM   #9
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
i am fixing my car, right now... i tried to take upper front cover out but couldn't remove wtf
maybe because of glue? help me asap! thanks
PIN GIO 2 is offline   Reply With Quote
